[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Mine wont rotate at all.
Ok the two people still having rotation issues. Mobile odin back to EL29. Open the settings app. Go to motion. And calibrate your Gyroscope. Then mobile odin sbrissens boot.img with CWM6 wipe data three times and wipe cache three times then flash nightly 4. DO NOT USE TITANIUM BACKUP TO RESTORE ANYTHING. then report back
Could it be the angle the phone is tilted? I couldn't get mine to rotate until I saw that it only rotates at a certain angle. Not sure if its my phone or not but its the only way I can get it to work
Sent from my SPH-D710
Weird coz it works fine when flashed with the first kernel though.
Need help..i never flashed sbrissens with cm6...i only wiped everything and installed Sprint nightly 3..is that still ok..or do i need to odin sbrissen and then wipe all and install skank 4 and gapps...i am confused in the part on requiring sbrissens kernel w cm6..thanks
Sent from my SPH-D710 using Android Central Forums
Re: [ROM][JB][08/21/2012] Jellybro CM10 [Nightly 4]
when i try'd to download from sdcard it said error installation aborted.
All my nightly ports come with the required CWM6. If you are on my nightlies already you do not have to odin anything.
If its your sd card you will need to back up everything and put it back in your phone then format it then restore all the data.
I was told you didn't need Odin so I skipped that already. I went into recovery mode then I backed everything up, and deleted the cache and stuff. After I tried installing the OP rom and the newest rom and both were aborted.....That is what I meant by I don't understand what went wrong......Could it be they were not for the epic 4g touch? Or something else?
Now my computer wont even recognize my phone. It charges but doesnt recognize it. I am running n3 do you know anyway to fix that?? thanks.
Seems my phone absolutely hates this ROM, I'm still getting LoS. :'(
Yes i have samsung usb drivers installed. My phone was recognized before i tried to download n4 after it was aborted i restored n3 now its not recognized :(
Are people having rotation issues all with US Cellular phones?
I am also. It doesn't seem to have a problem with Sbrissen's first kernel, so I just stick with that.
Status
wijana Topet
