[ROM][Sprint][JB][08/25/2012] Jellybro CM10 [Nightlies]
Status
Not open for further replies.
Yes i have samsung usb drivers installed. My phone was recognized before i tried to download n4 after it was aborted i restored n3 now its not recognized :(
Its now either your sdcard or its a bad download. Most likely its your sdcard.
Sent from my SPH-D710 using Android Central Forums
Reactions: gas101
Re: [ROM][JB][08/21/2012] Jellybro CM10 [Nightly 4]
I will factory reset my phone and see if that fixes it. Thanks
I know what gapps is in the OP, but what's wrong with the gapps_jb_20120726? I ask because I keep getting a notification from Goo.im to update it. Should I DK2?
Sent from my SPH-D710 using Tapatalk 2
Re: [ROM][JB][08/18/2012] Jellybro CM10 [Nightly 3]
front camera fc while taking pic -nvm rebooted an its working..
I can confirm that. Also, the video recording isn't good. My wife has the same phone un-rooted, so it is easy for me to compare.
The WiFi is working great and i didn't have any LoS in the past couple of hours.
Apart from this, do you wanna see something funny?
This is the first ROM ever to increase the battery instead of draining it, hahaha
And also the first one to ever have 3G with a phone call in the same time.
THIS IS EPIC...
All my nightly ports come with the required CWM6. If you are on my nightlies already you do not have to odin anything.
Great performance DK. One thing, I think the OP needs to be updated. You have to add that if you are using JB or AOKP (ICS) you can directly install these ROMs. That's what I do now with CWM6 and I never had a problem...
If that doesn't you are going to have to format your sdcard. If you have a microSD to SD card adapter you can plug it in your computer and back it up. Then put it back in and format it.
Reactions: gas101
I was told you didn't need Odin so I skipped that already. I went into recovery mode then I backed everything up, and deleted the cache and stuff. After I tried installing the OP rom and the newest rom and both were aborted.....That is what I meant by I don't understand what went wrong......Could it be they were not for the epic 4g touch? Or something else? Please help someone!!
So far so good! No issues I have found as of yet. Battery life rocks!! Phone has been unplugged and used for about 10hrs now and still have tons of battery life. 63% after using all day long.
Nice job DK2, SBRISSEN and everyone else involved! Thank you so much for the hard work and dedication!
Reactions: Dark_Knight2
OK, just for future reference. The md5sum checks are as follows:
ROM Nightly 4:
2ADC9A3D97CBB1C4347F83C03FB05418
GAPPS 7-17:
10988C023495B7871514F2D69CBC2503
I can confirm that they work.
DK, you do have the same hash, right?
Status
mattellis99
