[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
I'm not running any theme and didn't do the theme fix either. I wish I had paid attention to when it happened.
Nothing there. I know I didn't install a theme, but do you think your theme fix with the AOSP lock screen would work?
So this ROM provides a working CarDock? I presume one from the Mesmerize or something? Does the CarDock work fully?
Also... I see the browser still uses Bing? Does that mean we'd just have to install the de-binged stock browser?
It only uses bing for the url bar search. I cannot fix that myself, it requires the browser to be hacked up.
The cardock comes from the Vibrant.
Adrynalyne,
First and foremost, thank you for all you have done! It's great to be able to scour your threads and use everything you do for us all!
I flashed Supah Clean 0.4 after first flashing the DL09 full. Everything is running incredibly fast, but I can't get bluetooth to enable. It tries and ultimately just stops after 45 seconds or so. No force close, or errors.
Any clue?
Im not 100% sure, but I think blackmod enhanced will work directly with this rom. If not, you will want to flash the theme fix with it.
That said, Im still looking into why there is still an issue with the long press of search.
im running the blackmod enhanced theme and the theme hack w/ unlock and it runs great.
Considering flashing this ROM. Does adrynalyne's 12/30 kernel work with BLN to light up softkeys for a notification? I guess I can go to another kernel, but like to keep devs' files together. Second question if I don't go to this ROM, if I flashed the theme fix from OP in CWM over the stock ROM with TW, would that still mod the lockscreen? I can't stand puzzle. :mad:
Yes, adrynalyne's 12/30 works with BLN, awesome. Anyone who knows if theme fix will add ASOP lock to otherwise stock ROM setup, let me know.
yes, it will. i used the one with the menu unlock - download it from the OP and flash it via cwm: http://forum.androidcentral.com/fascinate-roms-hacks/53810-rom-dl09-super-clean-0-4-a.html#post526999
:cool:
Reactions: nigelengr
OK, so I am running this ROM, in combination with the 12-30 kernel. Any issues using the SonOfSkywalker Blackmod Enhanced Theme with this combo? ROM Manager says it's not for use with 1.x or 2.x series, not too sure what that means...
yes, it works great, im running it.
what that means is its a DL09 theme and not for use on earlier ROMs that were designed for DI01 and DJ05.
gotta love that black notification bar! :)
Reactions: 10001110101
Just what I was looking for, a touch different, and the circle battery meter is slick!
Adrynalyne,
Any clue?
Heya, thats likely kernel related...make sure its a DJ05 or DL09 kernel.
Thats because of ADW Ex.
Suspected that all along as that functionality stopped working after an adw update before ex was released, but was hopeful that this app could restore voice search long-press functionality. I'm guessing Awdex isn't honoring the link between the long press button and the voice search application.
Either way, i removed adw from system/app since i use ex as my primary launcher
Power button issue
im alive at five and gtg. :) nuance workin' all day long.
this is my best setup yet. love the black notification bar that comes with the Blackmod Enhanced theme. love the aosp slide unlock. love the power button menu with reboot, recovery, shutdown, etc. got nuance voice commands, insta-GPS and speedy menu flips, etc. swype rulez. and who doesn't love seeing an android pissin on an apple when your phone boots up? :cool:
mucho thankos to adrynalyne for the supah clean love; a well-deserved brewski has been purchased in your honor, sir.
AHA - I am having a bug with my power button. Short press, locks the phone no problem. Long press - no pop up menu, no nothing, phone actually freezes for a few seconds, un-freezes, then just reboots. Not a big deal since that is most of the time what i want it to do, but it certainly seems to be not right.
And still having the gps issue, won't lock on.
Any ideas???
Using supah clean with 12/30 non-voodoo kernel
Status
racoo
