[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Its entirely up to you guys, but I stickied a kernel thread, of kernels I updated to DL09 code.
Me too. Never tried anything close to rooting, but I must have this. Now. Definitely need a video. Ya know, for us noobs. :)
I've never read that before but I did cleared my cache from the unistaller on the YouTube app and it worked fine. Lesson learned. Thanks.
Is there a way to get the original SMS/MMS app back? I'm not sure if it's apart of Adrynalyne's rom or apart of the original DL09 package, but I personally like the older version better (the one that came with DJ05/DI01).
Other than that Adrynalyne, this rom is official baller status. Keep up the good work!
here ya go, installs via clockwork.
Reactions: xairrick
I've been trying to get the capacitive search key (long hold) to bring up the voice search.
Quick press brings up google keyboard search. long press works when I'm in the browser, but from the home screen it says "Application is not installed on your Phone"
I've tried installing the search_fix from the OP twice. I also have loaded the EnhancedGoodleSerachProvider.apk
Any help would be greatly appreciated.
BTW- Thanks Adrynalyne for this awesome ROM
Is the answer call when locked screen still supposed to be the puzzle? Mine is an is, just wondering if I did something wrong.
I'll take a look, and see what I can do.
Reactions: xairrick
Considering flashing this ROM. Does adrynalyne's 12/30 kernel work with BLN to light up softkeys for a notification? I guess I can go to another kernel, but like to keep devs' files together. Second question if I don't go to this ROM, if I flashed the theme fix from OP in CWM over the stock ROM with TW, would that still mod the lockscreen? I can't stand puzzle. :mad:
Yes, adrynalyne's 12/30 works with BLN, awesome. Anyone who knows if theme fix will add ASOP lock to otherwise stock ROM setup, let me know.
Also, adrynalyn, if you get an opportunity to address my post on pg 13, that would be awesome. I know you are but one man, so I don't expect you to tackle everyones questions at once. I truly love your work on the supahclean rom, my phone has never performed better!
Thanks again!
I have a question for you, Adrynalyne... I want to use your supaclean rom with swype (no problem there), but I had no luck in making the searcg soft key longpress to voice search... it still tells me "application is not installed on your phone." I simply downloaded the file from the first page of the thread, copied it to the root dir of the memory card. I went into rom manager and installed from sd and then nothing happened.
any advice?
another question I have, is that I want the notification window exactly like it is in sonofskywalker3's blackmod enhanced with the circular battery indicator AND the unlock screen that is on your mod...without sacrificing the performance that you gave us...
am I being too greedy, or is this actually possible? Sorry, I'm new to this scene, but am slowly finding my way...
Im not 100% sure, but I think blackmod enhanced will work directly with this rom. If not, you will want to flash the theme fix with it.
That said, Im still looking into why there is still an issue with the long press of search.
Reactions: martyr2k6
Thanks again, I really appreciate your response! Yeah, my main thing is that I want the looks of the dark theme, with the unlock from your rom. Also, not a big deal but I noticed when I received a call that the puzzle unlock did make an appearance.
So my ultimate goal is to have this baby running that theme, with your unlock and your rom.
Again, not trying to be greedy but if you can offer a how to, that would be great!
Thanks again!:D
Go into rom manager and look under son of skywalker. He designed the blackmod enhanced theme and actually has a DL09 version. You should be able to run this. Even the DJ05 themes are fine if you run the theme fix posted in the 1st post.
I am running the DJ05 Nextang theme ... I think that is what it is called :)
I just noticed something, right after I installed your rom I had the standard Android lock screen. At some point though, it reverted back to the puzzle lock. I don 't know how it happened, it took me a while to even notice. Is there anyway I can change just the lock screen?
If you installed the standard theme fix with a theme, that would happen. Otherwise, if you are using vooodoo, it can be toggled in red clockwork.
Status
racoo
