[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
I get blue first and then run the update.zip.
I just flashed back to 2.6 and will begin the process to frank again when it finishes booting.
Thanks!
From reading Adrynalyne's post from this morning, if you got stuck at boot trying to install the full superfrankenclean 2.7 ROM, you are going to continue to get stuck and the ROM will not work on your phone. Your only option is to flash the sc 2.6 rom and then the patch which will only give you what is listed in his post from this morning.
OK, everyone. I'm going to answer you all in one post. Take a look at the first post in this thread. See how as you scroll down each version of superclean is labeled and each version lists a changelog of what was changed? Those are complete ROMs. See how each one is labeled and how there is a voodoo and a non voodoo version? Those are complete ROMs. Now look at 2.7. Does it look like the other versions? Is there a heading listing 2.7 then a voodoo and a non voodoo listed under that heading? Is there a changelog listed? No, there is simply a patch listed. There was a 2.7 heading yesterday with both a voodoo and a non voodoo listed. Those are gone now because Adrynalyne has pulled both. The only thing listed in the first post is the patch which only installs what Adrynalyne listed in his post from this morning.
If you already downloaded one of the ROMs to your phone yesterday and got past the boot stage Adrynalyne is saying you can keep and run that ROM with no problem. If you get stuck at boot with the ROM for more than 5 to 10 minutes, the ROM will not work for you and your only option is to flash the patch in cwm which will not give you the full ROM. If you do not currently have the ROM downloaded, you are not going to be able to get it unless someone who has it is willing to send it to you. The full superclean ROMs have been in the neighborhood of 140MB. This patch is only 1.75MB, and is just like flashing any of the patches listed toward the bottom of the first post in this thread such as the nuance patch, the stock clock patch, TW patch, etc.
Check again 2.7.1all.zip is well over 100mb
Sent from my SCH-I500 using Tapatalk
Mine boots to the blue recovery then I have to load update zip. Is this bad?
No but people were having boot issues with that recovery yesterday. Try using Cwm_recovery_all. That one was have better results yesterday.
Thanks. I ran the patch this morning and all was well and then I saw Adrynalyne's post about the full superfrankenclean and that it would better protect against threats and thought I'd do that.
Regardless, I returned to 2.6, then ran frank again and the kernel (no reboot between) and it hangs. I'll just return to 2.6, run the patch and stick with that for a while. Then I should back away from the computer and phone and do something else besides be obsessed with this! :D
Sorry for the confusion everyone. I was out last night and it seemed wrong that because of Edify, the improvements/fixes I made would not be available.
So I made the patch.
The patch contains Chris3D's debinged browser, and my modified Samsung MMS. I backported the features from the eb16 app into the eb01 app, making a more feature rich app between the both of them.
To clear other things up:
Edify is merely a scripting language to install the rom. It doesn't affect usage past that (with an exception). Previously, I used Amend, as did most everyone else in the SF community.
Clockwork 3.0 only supports Edify, whereas before Amend and Edify were supported. So I am attempting to update all my stuff to Edify, for those who want to use Koush's new recovery.
The patch only provides two APKs, and will work fine with non voodoo or voodoo. It installs with Edify. The kernels, are still Amend, so you must use clockwork 2.5.x to install it, not the new 3.0.
The original Nonvoodoo snafu was entirely of my doing. I had accidently left a voodoo recovery in. Now, it didn't affect everyone, but I still feel bad about it, because some of those ended up using odin.
The voodoo rom worked fine with Edify, UNTIL it came time to convert to voodoo, or disable it. For some reason, the system will not mount, and you get a "system unavailable" from robo chick. This doesn't happen with Amend, which was used in 2.6 and before.
All of the patches are currently Edify ready. The kernels are not. Until I can figure this out, I will either:
Keep using Amend on my roms, or, stop including the kernel in the rom, and have the kernels use Amend.
MOST IMPORTANTLY:
If you have 2.7 installed and working, don't worry about it crapping out on you. The issues are ALL install related. So if you got past that, you are just fine.
Ok everyone, here is Adrynalyne's post from this morning. He is saying you need to flash the patch in orange cwm. He is also saying the EB16 tethering kernel needs to be flashed in red cwm. The instructions for how to have both red and orange cwm on your phone and how to switch back and forth between the two can be found on pages 13 and 14 of this post:
[RECOVERY] Updated ClockworkMod for ALL ROMs - xda-developers
Did you ever get your answer to which cw red or orange will install this?
No. but I'm going with cwm_recovery_all. Its the red one that boots right into cwm bypassing the blue screen and w/o the error messages at the bottom
Hey landshark there is a new thing up its 2.7.1 its not a patch. I got the patch early today and this is a rom its 119mb big so thats way diff then the 2 mb that was the patch.
Yeah, Adrynalyne snuck in there while I was typing out that war and peace novel. Well at least it was relevant and correct AT THE PRECISE MOMENT I was typing it. :p
Yes there is now a full rom up n dryn advises we use it due 2 new malware threats...this new verdion hsd no kernel so u nd 2 flash one after the rom voodoo or nv ur choice...my ? Is.do u instal the rom from new yellow/orange cwr then the kernel in red cwm our can both be done in red cwn
Please let me know if there are any install issues. I can't forsee any. I flashed it with red and orange, and it was fine each time.
Where is he saying that?
Supposed to be the quote about orange for 2.7.1 - sorry
At the time I was typing that I did not know 2.7.1 was up already. He said the patch (not the 2.7.1 ROM because at the time the 2.7.1 ROM was not posted yet) was Edify which is flashed with the new orange 3.0 cwm.
So to clarify for everyone - adryn just said red works for both the 2.7.1 and the eb01/eb16 kernel, so everyone just use that for now!
So to clarify for everyone - Adryn just said red works for both the rom and the kernels, so everyone just use that for now.
SO TO CLARIFY FOR EVERYONE - ADRYN JUST SAID RED WORKS FOR BOTH THE 2.7.1 AND THE EB01/EB16 KERNEL, SO EVERYONE JUST USE THAT FOR NOW!
+1
i just flashed it, a min ago. just waiting to reboot.
Did it from red. already had the kernel(EB16NV). wiped cache and D cache. will let you know my findings in a few.
Okay so can someone please just say yeah or neah. I have downloaded both 2.7.1 all and eb16 voodo. I am going to wipe and clear cache and dalvik and then install 2.7.1 and then the kernel and than boot.....coorect?
So my phone ends up hanging at the samsung logo. I wiped cache, dalvik cache, installed 2.7.1 from the zip, and then I did wipe batt stat and then I did reboot. Did I mess it up cause I did wipe batt stat after installing the 2.7.1? How do I fix this? I did this in red mode. Thanks in advance.
I flashed 2.7 patch last night if that makes any difference.
Flashed 2_7_1_all.zip in red cwm then eb16 voodoo kernel then rebooted n all.went well n phone is runnin great so far (been about 5 min since phone booted up jys wanted 2 report no problems w flashing the rom here)
Status
BigHugh
