[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Thats not what I asked...what did you update over, that you are no longer booting?
I went from sc 2.6 -> sc 2.7 patch -> and then the sc 2.7.1 and after I rebooted it just froze at the Samsung part......does this answer your question? Sorry if it doesn't.
Did you enable lagfix, because if not, then after setup is done, boot back into RED CW>voodoo>enable lagfix then menu button>reboot. Should hear lady android.
Thanks will do... I did it but did not hear a female android voice...
I had 2.6 and then applied the 2.7.1 and was stuck at Samsung screen. Would not go past it. Started from scratch and same thing happened.
I am a noob with all of this so not sure if this is the correct steps or not. I know I get 2.6 superclean up and running fine, go to recovery, apply 2.7.1, reboot and stuck at Samsung screen.
I am going to ODIN back in time to Full Stock Froyo Leak+root+Froyo Clockworkmod EB01_DXC.tar and then try the 2.7_all ROM and see if that helps.
If that doesn't work then I am going to go back to 2.1 stock and try it from there.
If that doesn't work I am going to stomp this phone into the ground.
try flashing this:[RECOVERY] Updated ClockworkMod for ALL ROMs - xda-developers
right after you odin, the cwm that comes with that package is what I think is causing your problems
Reactions: DerekCA
I came from the same setup as the people that are having issues but it worked fine for me. I think its a cwm issue and it might help if people re-flash this:[RECOVERY] Updated ClockworkMod for ALL ROMs - xda-developers
prior to trying to flash 2.7.1_all
Last two times I used Odin to flash this CWM I would go into recover at blue screen. When selected to load update.zip it would bomb with an error....
If I try this again and I get the same results do I need to start over or can I get the one 2.5.1 that I am using back easily?
doesnt use a update.zip to get into cwm
delete the update.zip from your SD card and re-download the odin file from the link above and try it again.
*Rips hair out*
2.7.1 has been yanked until i can get a proper group of beta testers together.
I just installed 2.7.1 with Eb16 voodoo kernel over 2.7 voodoo from yesterday and it works fine for me. I'm using cwr 2.5.1 red still and have had no issues with any of the last 2 rom versions.
What do you need for beta testers? i can switch over to my continuum and test on my fascinate
Status
Cheezy313Bby
