[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
How can I run the stock theme for froyo? Is there any download for that? The superdark thing is ugly.
I'm having the same problem with the fb contact pics on the stock sms! and also--texts aren't going through to a lot of my friends. Well they say they go through--but my friends are not getting them...
and handcent was doing the same thing... saying they go through, when the other end isnt getting the sms.
I believe the stock bloated Froyo is HERE
I don't believe there is any packaged up version of this for Odin like DroidXcon provides in his post in the stickies.
I mean, the actual theme, not the stock rom. I like superclean but I don't like the theme it comes with.
Also, I can't get boot animations to work - whats up with that? :(!
Cant tell you why it happened, But I can tell you how I fixed it.
Backed up all contacts with backup assistant.
Deleted all contacts from phone (Not sure if this is really needed)
Deleted facebook account from phone.
reboot
Restored contacts
Open contacts, Menu, select get friends and add facebook account.
Sync facebook.
(Before deleting my contacts, I went to my verizon and exported my contacts
to a file on my PC, just in case)
Hope this helps.
I have a question regarding the 3g data, since i upgraded to 2.6 i noticed that if my wifi is off and the phone goes to sleep for a long period the 3g data signal will disappear and i cant access the web or email wont sync. I am not sure if this is a feature of 2.6 to save battery but for me to get it back i need to tap on 3g data off and on again or turn wifi off.
I followed Ady's post on how to fix your phone after he screwed it up.....and now I have gone Voodoo!!!! Downloaded 2.6 and eb16 voodoo. So far so good.
Thanks
I think what you are asking is how do I get back to an unthemed phone.. If that is what you want just reflash the ROM. Superclean in your example and you'll be back to either an unthemed phone or whatever theme the ROM had in it. I just reread your post and see know that you don't like the theme that's in superclean.. You can either flash a different theme... I'm not sure if someone has packaged a STOCK theme... Check the stickied theme/rom post here that lists all of the themes.
If you want to just play with a theme you can do a nandroid backup from cwm before you flash the theme and then restore the nandroid backup if you end up hating the theme... the nandroid backup/restore is a little bit of a lighter process then flashing the ROM again but not much :-)
I have the 2.7 running and have a PIN set to secure my phone. Yesterday when I was attempting to install the 2.7 from 2.6 I had a problem getting the phone to accept my password. After getting 2.7 installed and running this morning I turn on my phone (after having it turned off and charging overnight) to discover that it again is not accepting the PIN. I know the PIN is correct so it seems like there's a bug somewhere. Anyone have an idea how to get past this? Is there a "default" password it might have reverted to? If I can get into the phone I'll turn off the PIN lock...
I am running 2.7 from the patch. Everything seems to be OK but the battery life took a nose dive again maybe 12-14 hours before dead. It was actually getting better before the patch to 2.7. Anyone else get the same thing. I have even gone into setting and put wifi to sleep when screen is off and it did little. Spare parts shows wifi on 100% but used at a more lower %.
Can I use CWM (the ones that goes strait to red v3 I think) to flash SC26 or will that screw things up? Also regarding SC the update.zip file on the sd card does that still have to remain there? Do/should you run it under red?
Thanks
If there's been no problems with the voodoo install, could it PLEASE be put back up for those of us that are on voodoo - PLEASE!!! And if not, does someone else have it somewhere I can download it from. Thanks SO much in advance.
My buddy's X's gmail account got taken over, and with the scares of the market recently, I'd really like the added protection plus just to be running 2.7. Thanks again!
Adrynalyne was having problems with voodoo also, so both 2.7 versions are pulled until he is satisfied they are stable.
Hey Adrynalyne,
Thanks for the awesome work. 2.6 working great.
Patches don't seem to apply in CWM Orange. Tried Thinkfree and Nuance and neither are there when I reboot after applying the zip patch in recovery mode.
Thanks so much again!
Is super_frankenclean_2_6nv.zip meant to be flashed over super clean EB01 non voodoo? I at one point had a voodoo kernal. I disabled it and updated via Odin to EB16SC26_DXC.tar. However, the about phone tells me I have EB01 as my build. Is this correct? And if I want to update to voodoo kernal do I just flash the voodoo kernal from CWM 3.0.0.8?
Hey Adrynalyne,
When Adrynalyne was having trouble with 2.7 and pulled it he did a post in this thread outlining what needs to be flashed in red and what will need to be flashed in orange. Patches are still flashed in red. He is converting things to be flashed in orange and as great as he is, I'm sure he will update us as to what is now flashed in Orange. You just have to go back a little ways and read to stay current. By the way, the post outlining this is at the top of page 195 of this thread.
EB16SC26_DXC.tar INCLUDES superfrankenclean 2.6. Every superclean version since 2.0 has been an EB01 build. The two Froyo leaks we have had so far have been DL30 and EB01. So far Adrynalyne has put together 7 different superclean versions that have all had EB01 builds. There is no superclean EB01 non voodoo, you either have superclean 2.0, 2.1, 2.2, 2.3, 2.4, 2.5, or 2.6 - all of them are an EB01 build. Why did you disable the voodoo kernel before? If you aren't completely comfortable flashing roms, themes, kernels, add-ons in cwm, the general recommendation is to stay away from voodoo until you are comfortable doing all those things in non voodoo. Just too easy to slip up and flash something non voodoo over the voodoo kernel and brick your phone.
What is orange CWM, have not seen that one yet.
Is that when you run update.zip from red cwm? <edit> just tried it does nothing but put you into red again.
So red is still version 2.5xxx and Orange is 3.xxx? I thought the red that you go stair into without going to blue was 3.xxx? Man this is so confusing.
Thanks
Yes, you would flash sc 2.6 through cwm. If you are on non voodoo, update.zip needs to stay on the base of your sd card. Yes, run it in red.
Status
ahmadirsyah
