[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
i installed the froyo and then tried to install the superclean dl30 but it failed...should this be installed from stock software instead or should it work?
is it installed via the red menu as froyo is?
sorry, im new to all of this
I formatted everthing inlcuding my SD card before doing the DL30. I moved my pictures but not my downloads, where can I get the .apk's for genie widget and aosp desk dock?
Thanks
its all good. you have to use the new cwm green. the old works for some but the new works for all. so go with new. flash with odin and then rom manager. in that order.
im having trouble with gps and the audio out of the car dock still dosent work. i would also like to ust the google calendar instead of the tw calendar. anyone know where i can goet one?
so far everything else works great!
ok. CARDOCK WORKS!!!!!!!!! you have to use the stock music player. :( but i will take it!!
oh, in case i forgot, adrynalyne, you ROCK!!
Great work! Thanks for making it super-super clean and allowing us to only flash the bloat we want/need for specific functionality. You sir are excellent.
thanks gunner...can someone post where i can download cmw green?
do the menus and install work the same as the red?
You can find both Red and Green in the Stickies under Modified CWMrecovery for ODIN -> http://forums.androidcentral.com/ve...lus-new-root-instructions-updated-1-15-a.html
Pretty sure they work about the same except green gives you fewer options. I accidentally flashed red before coming over to superclean.7 and switched back because I didn't want to jump into Voodoo world yet.
Someone with more knowledge please correct me if I'm wrong.
hmm..theres quite a few files in that post..do i need all of them to get this running? busybox, kernel, 2 odin files
to install froyo i just needed a odin exe and a cmw tar file.
and it said to ensure using pda rather than phone option in odin so you don't brick your phone..is it the same for this version of cmw?
@flamingoezz
When using ODIN
! ! ! NEVER NEVER NEVER use Phone! ! !
ALWAYS use PDA
All you should need is the ClockworkMod Recovery Odin Package and have the update.zip on the root of your sd card.
Sent from my SCH-I500 using Tapatalk
So, I tried doing this and now my phone won't go past recovery mode.. At first it would just stick on the Samsung logo. I was using DL09 and had Voodoo lagfix running. Now it keeps telling me (whenever I try to restore) that it can't mount sd-ext and that it will skip it. Then it just reboots, and loads restore mode again.
I appreciate this, dude. Now I just need superdark theme for DL30.
You only need the super clean zip, install in cwm
No odin necessary. I would wipe data/cache. DISABLE VOODOO
Status
kathynickerbutt
