[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
i have to go back too DL09 after trying to flash this??
and reason why i got errors and couldnt boot back up?
I'm attempting to flash to Superclean for DL30, and I get the following error:
E:Can't mount /dev/block/st19
(No such file or directory)
E:Can't mount SYSTEM:
E: Failure at line 4:
copy_dir PACKAGE:system SYSTEM:
Installation aborted.
Thoughts?
I'm attempting to flash to stupidfast for DL30, and I get the following error:
Thoughts?
That kernel does not work with DL30. There are no kernels currently available, other than the one installed with the ROM, that will work with it.
Hah! You added recovery and download right into the power button ! ? ! Awesome, thanks again you your handy work.
Sent from my SCH-I500 using Tapatalk
GAH! Sorry, I meant Superclean. Not Stupidfast.
*edited*
After the error, I backed out and went to reboot... and now it's stuck on the Samsung boot screen, too >_<
Need more detauils that lead up to this. Those errors are typical of using an incompatible recovery.
For those who want it:
launcher2 patch to add it back into any future version is on first page.
I flashed to Froyo, downloaded the version of superclean that you linked in the first post.
Put the zip on my SD card, powered down, went into CWM Red, attempted to install from SD "DL30_Superclean_08.zip"
and got those errors.
Those are the only steps I've taken.
Just reflashed DL30 and phone is functioning properly again, just can't seem to get Superclean up and running.
i did the same and got the same results
Did a bit more reading, I apparently missed the fact that there's a new CWM etc. to flash as well. I'll get on all that and update progress.
sorry if this has been asked but am i able to remove anyapps i dont want like the live wall papers and voice?
I loaded the rom in green CWM. Flashed the small touchwiz file and I have been good. I have a few other apps I installed off the full version. I hope that Nuance won't be needed as Froyo on my D1 handled it fine but I will see tomorrow.
The power options and battery % mod are excellent additions. I will have to find a good theme soon but this is a sweet setup. I have not done much but I notice lag with ADW on the horizontal app drawer. I like the horizontal scroll for some reason ;) I will try some other methods but hopefully ADW will still work well.
I believe someone over in the original DL30 leaked thread posted they bought root explorer in the app market and are able to move and remove what they want using that.
Does anyone know what the Launcher2 zip that Adrynalyne added is? I downloaded and flashed everything from the first page of this thread except the samsung keyboard, and I'm loving this set up. Everything seems to be running smooth and quick. Just thought I'd ask before I downloaded and flashed it just to see what it is.
@Landshark
The 2.2 Launcher is the one Adrynalyne included in SuperClean.7. The launcher her used in SuperClean.8 is 2.3 and I think he also said that he modified it a little bit. There are a few differences between the two, but nothing major. Both have worked well for me.
Speaking of launchers... Does anyone know if there is a way to remove homescreens with 2.3? I've pretty much only used LauncherPro up until this point. Thanks!
Love using your ROMs... Quick question though. I updated to your .7, and am noticing the google widget is not searching contacts (all google,btw).
Is this a known bug?
Status
kacperwampirek
