[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
I have a problem and hope someone can help.........I am using the Froyo Super Clean Rom and when I take pictures they do not appear in the gallery but I can find them on the SD card........Same thing when it scans for music which is on the SD card and a similar problem with contacts on the card.........The card works fine and was fine with 2.1.......Any suggestions of what I can do?
Thanks!!
How do you change from Red CWM to the new Green CWM? I've memorized how to use CWM to install .zip files from SD, but I can't remember how to install or switch versions of CWM if I ever did it at all...
my appologies if this has been mentioned before.
installed super clean dl30 and super dark theme last night but i cannot get my facebook sync to work. i go to settings>accounts>add>facebook and it does absolutely nothing. if i click gmail or yahoo or any other account it pulls up the menu to add my email address and password but facebook does nothing. thus i have no contacts in my phone book. any help would be greatly appreciated.
looks like its a known issue with super clean. just gotta download the extra parts to get facebook sync.
Wow. Woke up this morning and I have the circle with the line through it basically meaning I have no service. Airplane mode cant be toggled either as it gets stuck. I tried wiping cache and dalvik and reloading .8 completely. I have not wiped data as I really don't want to go there. Anyone seen a solution for this?
Can I load the DL09 radio via Odin again? Not sure what caused this as I did nothing different to the phone last night.
I had the same issue show up. About 4 am my phone rebooted itself and was stuck in airplane mode when it restarted. Hopefully someone knows what happened. I just got home and am trying to go about just getting my phone to work again. Kind of sad this happened I was really liking this rom. It's the first issue I've had since installing it.
Its your radio.my phone did it last night also and I was running stock.that was the first time that has happened to me.now you say it happened to you the same night. I wonder if verizon sent a bad signal out ..anyway first thing I did when I got home was flash a new radio..when I get to work il l get you what you need if you want
Sent from my SCH-I500 using Tapatalk
I re-loaded the DL09 radio via odin and I am back up. Not sure what happened though.
I'm reloading DL09 also right now. I don't know what happened either it just rebooted itself and I hadn't done anything since I upgraded Saturday to version 1.0.
Phone up and running now after flashing Dl09 with Odin and now just to get it back to where things were.
kevin is correct. i am downloading it now. im glad you posted. i have always thought the asop desk clock was missing something. i just automaticly assume the stock stuff is inferior to the asop. i should know better, the stock mms is pretty cool, deffinately better than the asop.
I agree! I prefer the Samsung MMS and clock apps.
What rev is it? I didnt test it yet, i went straight for the froyo build... I swapped DeskClock.apk in the superclean rom, for the ClockPackage.apk in the DL30 froyo leak. It looks like it works so far (it runs at least) i will have to test the actual alarm capabilities once I am done with work.
Edit: this worked great. I have my fade-in alarm back!
How did you go about swapping the two apks?
Hi guys. I just upgraded to the dl30 superclean 1.0 and followed the froyo upgrade instructions stickied here (just subd superclean for the basic froyo zip in the instructions). I was using the dl09 superclean pre upgrade.
Everything is working great except for the email app. I get force close notifications every time i power on the phone. I'm also getting audible selection and haptic feedback, despite having both disabled in the Settings. Any advice?
You extract the desk cradle from the dl30 leak rom. You can do this from the phone. It will be in a folder called extracted on your sd card. Just copy that into your system folder.
I like the look, but the weather wont load and I can't add cities. A couple of the other things don't work either. I still like it. I just want the weather to work. I can live without voice search on my alarm clock. Don't try and install it cause it wont. Copy to system>app folder.
Reposting this:
Thanks!!
Reposting this:
Thanks!!
idk they show up for me what sc u ruinning...
Status
Miserydhala
