[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Updated to 2.1.
I don't normally do stuff like this, but if you feel the need to donate to the "get my wife a nook color for valentine's day fund), my email address is adrynalyne at gmail dot com. Im about 90 short.
If not, thats cool too!
Voodoo and non voodoo superclean versions have been posted. Both flash working recoveries.
I wish I had some money to donate. So badly. You've made my life better. I wish I could repay you. Thank you so much for your work, it's incredible.
I am currently on super clean 1.0 with super dark theme and I used cwm red to flash. When I boot into recovery it showes options for voodoo and lag fix but they won't enable? Is this because super clean 1.0 is not voodoo? I'm asking cause I think I want to change to eb01 super clean and I'm not sure if I can use the voodoo one.
Sent from my SCH-I500 using Tapatalk
I'll make a patch when I get a chance. Not a huge fan of it, so I don't think it will make it back into the rom, however.
what about something to switch the audio to the usb for the car dock so that you dont have to open the stock music app and play something just for that button to come up? i like the aosp music app but have to use the stock for that button. you also have to use the stock music app to play something with audible or pandora.
Yes that is correct it is because super clean 1.0 is non-voodoo. If you want to use the voodoo version of eb01 superclean, follow Gunnermike53's instructions here:
http://forum.androidcentral.com/ver...s/55753-how-voodoo-updated-12-feb-2011-a.html
Be sure to thouroughly read his instructions and pay heed to his warnings about making sure you are completely comfortable with flashing roms, kernels, etc. in non-voodoo before attempting voodoo. Happy trails.
Dang I just installed 2.1 last night too.... Anyway to just install SNS without redoing the whole installation?
Do I need to wipe data before this install I am on sc 2.1
Install what? I just noticed Adrynalyne has updated to 2.2. Are you referring to that? It is strongly recommended you do a full wipe (data/cache) before flashing any new ROMs. You can flash between themes without wiping anything. But flashing new ROMs/kernels/radios/modems requires a wipe. Just do a nandroid backup of your current build so you can always go back to it.
yes, you can flash the SNS without redoing the whole thing. Probably would be a good idea to wipe cache and dalvik cache before you flash the SNS
what about flashing the whole 2.2 SC package? Can I do that without reinstalling everything?
Some of the more experienced people could probably answer that better. From what I have learned and read through reading these forums and trial and error, you should always do a complete wipe when flashing a new ROM or kernel. Make sure to back up your apps through titanium backup. The more experienced people here suggest backing your contacts to your google account, but I am still new so I still use backup assistant.
Reactions: jbr05ki
Ok that's what I thought. I used the ODIN package DroidXcon created. How would I install this? Do I do it through Clockwerk or Odin?
Post SC 2.2 and theme Superdark install, I do not have the black market. Did the theme overwrite the ROM?
You already have everything you need, download 2.2 to your sd card, reboot into recovery, apply sd card:update.zip (use the home button to choose), wipe data/factory reset, wipe cache, you can also wipe dalvik cache under the advanced option if you want, install zip from sd card and choose 2.2. Once you have everything you want installed, hit the menu button, reboot system now. Make sure to back up whatever you don't want to loose (apps, contacts) so you don't have to reinstall them one at a time.
Reactions: jbr05ki
I'm not sure if this has been answered here, but does the download of voodoo 2.2 in the op include the voodoo kernel? then I only need to flash the one .zip in CWM and enable voodoo?
Thanks
Edit: if it does not include the kernel, where can I download one, and which do you recommend?
I tried this but it didn't work. It's the blue recovery btw. Do I gotta rename the 2.2 sc zip file to update.zip?
Status
BekaH
