[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
How much faster? - I'm getting pretty good at flashing - with all these updates that keep coming out. Feel like I went from a beginner to an expert in about a week. Are there any other things that it can do - or it's the same but just has a different installation method and operates a little differently. And thanks so much for the reply.
hey brett, i gave an explanation of what voodoo is in the first post of how to voodoo. tells you waht it does and what to expect. if you need some clarifacation on anything jsut ask.
Reactions: Brettdacosta
Apologies if this got resolved already in a post I missed...How can I change it so the voicemail button on the dialer goes to visual voicemail instead of Google Voice? I'm running Superclean EB01 v2.1
First off I would like to thank you for making a super fast, slick, and easy froyo release! Within a few minutes I had my phone running froyo and all my contacts/apps back (and I'm fairly new at this). Secondly, the Back button isn't working when I'm in my Contacts, but works everywhere else. It's a little problem so I'm not concerned but any advice would be great! Thanks again!
You guys are amazing.. Your answers about wiping and using full version of titanium have allowed me to update to latest super clean tonight while at a restaurant with friends.
Will hit the thanks many times when I get back to pc.
Via Tapatalk on SGS Fascinate.
Hey, I just installed Superclean today and I noticed that 1. Battery life is improved, lost 15% in about six hours, I can deal with that. But 2. When I charged, I saw 84%, but no notification in the battery icon in the notification bar. It still showed completely full. Any one else having this problem, or know how to fix it?
I noticed the same thing earlier today. I was at like 86% but the battery icon showed full. I loaded a theme with a circular battery mod with the percentage so I don't know if that is still an issue. And I have also noticed improved battery life with superclean 2.1
I was getting the same screen not waking up in the morning as I did with DL30. I had to wipe 3x today and start from scratch. I hope that this takes care of it.
I lost brightness control through the notification bar after updating to 2.1 from 1.0... Normal?
Do you have automatic brightness checked in settings=>display settings=>brightness? I have read in other posts if you have that checked you will not be able to adjust brightness. If you uncheck the box apparently you will once again see the brightness control
EDIT*
Scratch that. I just unckecked the automatic brightness box and I did not see the brightness control in the notification bar. But good news is I just remembered reading there is a cool new feature with Froyo. If you have the automatic brightness unchecked you can long press the notification bar and slide your finger back and forth to adjust the brightness.
Thanks man! I forgot that I had to do that last time to get it enabled! All this flashing it making wipe data in my brain!
LS which theme did you load with the circular battery%? where did you get it?
Thanx ;)
Thanx ;)
I flashed touch of blue. all the themes are here:
http://forum.androidcentral.com/ver...mes-kernels-updated-2-11-11-eb01-updates.html
All of the themes have previews which are screen shots of what they look like. For touch of blue you have to click on the devs name which will open up an xda thread where all the downloads and options are. I was not able to left click on the links to download them, I had to right click on the links and choose "open in new window", then the download prompt popped up
Reactions: LakerFam0824
You can find a list of themes in the sticky section
I'm using SuperDark for EB01 and it includes the circular batt. I'm not sure which themes use it, but you can look at the preview shots to ind one you like. You may also be able to simply flash the circular batt. alone but I'm not where to find it.
edit:: Dangit Landshark let someone else answer Q! I like catching the easy ones because it's all I am capable of.:-[
There is also a link in that thread for different power and battery options. JaeKar99 has put in a lot of work into gathering all the information in there, watching for updates, and keeping the thread current so make sure you thank the heck out of him when you are there
Bluetooth issues?
Is anyone having any issues using bluetooth on the new build EB01 sc2.1? My phone says it has paired with my logitech z515 but everything still comes out of phone speaker. My wifes stock fascinate pairs up and plays, so I know it is something with my phone. Any thoughts?
I can't get the voodoo .zip file from media share to download. It just keeps acting longer it's going to, but then it basically just resets the page. I am trying too download out on my phone, so there could be some setting that is leasing it up, but I earlier today I downloaded the non-voodoo .zip just fine?
Status
Lassi876
