[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
I have read through some (not all) and can't find an answer. I am running superclean 2.2. I am using the stock launcher included in this package. Everything looks great. On to my question. Is there anyway to add/remove pages from the home screens? Is there anyway to change the order of the launcher pages? And finally, is there anyway to change the actual homepage? (the screen that the phone goesto when the home button is pushed). I know on the Touchwiz launcher, you could reorder/change/add/delete the home page, just wondering if this is possible on the launcher on superclean 2.2? Thanks, and sorry if this has been asked previously.
no you will have to use a different launcher. i use launcher pro. install launcher pro. move it to system app folder. delete old launcher. done.
Ok, getting an issue. running 2.2 nonVoodoo. I keep freezing. I cleaned all cache, still froze. So I refreshed and cleaned user data in CWM, and re-installed 2.2, still freezing. I am running all the same apps I was running on 2.1 with no problems.
Can anyone help? Do I need to go back to EB01 then up to 2.2?
how are you reinstalling the apps?
can someone post a link to the eb cwm. im dl 30 now and im trying to flash superclean 2.2 thanks.
Does anyone know where to get the stock alarm clock application? I think it is better than anything else I've seen out there. Can I extract it from the original ROM and then just copy/paste the .apk file and install?
i will answer your second question.
yes.
you cant install it, you have to paste it to the system/app folder.
good thinking. if you dont know try it, the worst thing that could happen is you brick your phone.:D
I just wanted to say thanks personally. I flashed the SC EB01 2.2, and I'm actually in love with this phone all over again. I've already "given thanks" in this thread, and the original source thread, but again, I wanted to say thanks personally.
The only thing I installed is BW. That's it. Everything about this rings perfection for me.
Is anyone having any issues using bluetooth on the new build EB01 sc2.1? My phone says it has paired with my logitech z515 but everything still comes out of phone speaker. My wifes stock fascinate pairs up and plays, so I know it is something with my phone. Any thoughts?
Just tried this today. Mine did the same. Played through the phone not the bluetooth. Are we missing an app that was removed?
Has anyone noticed with the new 2.2 images that the phone does not recognize the multimedia desktop dock and does not go into clock mode when it becomes docked?
Is this something in which there was a patch or something already posted that I have missed?
yes, i did notice that as i have that dock and use it as my bedside alarm clock and i like the convenience of inserting the phone into the dock and having it automagically going to the Clock, which i like a LOT better than that damn TW thing, which even in the night mode blinds you to death. but the downside is you lose the timer/stopwatch but oh well there's prolly apps for that. :)
i was going to wait a bit before bothering adrynalyne to see if he could take a look at this cuz its not a huge thing but, dude, if yer listening and dont mind i wont hate ya for it. :)
you can grab that from the FASN8 dump file - a dump of all the original stock apks.
the question is, are you running a non-deodexed ROM (e.g., stock and unrooted) or are you running a deodexed ROM, like most custom ROMs?
you can grab the DI01 original non-deodexed system dump file from here: fascinate_sys_dump.zip
or you can find the DI01 deodexed version buried within the zip file found here: RELEASE: Deodex'ed DI01 System. (Flashable through Clockwork) - xda-developers
it should work with the latest ROM's but you never know until you try. :)
Reactions: surfthesummer
I don't have any power options. When i hit power button it just vibrates like something forced closed then reboots. How can i fix this? I'm trying to run superclean 2.2 non voodoo
I have a question, sorry if it has already been covered: With the super clean 2.2 nonvoodoo does anyone have issues with the back button when you go into your contacts? The back button seems not to work when I press it while my contacts are open, not a big deal just an inconvenience.
Ytaay: Whats the dock issue?
on DL09 and prior, the Clock app would fire up automagically when you inserted the phone into the desk dock (just like the TW Desk Clock app) but now it doesn't. i dont see any app setting for this so it must be hardcoded.
if you have any ideas/thoughts, cool. not a big deal.
ive got Tasker; i should try to set up a Tasker script to do it.
Ah I see, that is weird. Thanks for the quick reply.
Dr. K_Xen: Its been an issue with Launcher Pro. I've not had it happen with any other launchers.
Just an FYI, my back button works fine in Contacts and I am using launcher pro. I guess it doesn't effect everybody.
I'm working on it. I thought I knew what the issue was, but it turned out to be a dead end.
Status
rex9090z
