[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
i use my own ring tones so i havent noticed. just pull the ring tones from the good builds and drop then in you phone.
So If a guy (me) wanted to remove some of the stock ringtones/notifications you could just remove them from the folder? - Just trying to understand some of the basics :)
Sounds like you may have flashed a theme over this. Not a good idea. Might want to reflash rom.
ive never installed a theme to my knowledge. i didnt see the transitions zip in the post the first time so i reflashed with same result (on epic transition this time).
heres what i did.
flashed from dl30 superclean back to dl09
odin to cmw red
restored factory settings/cleared cache
installed update.zip
flashed new superclean voodoo
installed zip for battery percentage (eb01 version)
installed transition zip
enabled lag fix
rebooted
it boots fine, i setup gmail, facebook etc. its not until i mess with transitions that i gets stuck in a boot loop
heres what i did.
odin to cmw red
enabled lag fix
rebooted
did you flash a voodoo kernel with ODIN? I didn't see that step mentioned in there unless the DL09 you flashed back to was voodoo
EDIT- my bad, superclean has the kernel in there. I meant did you flash the EB01 modem?
EDIT FURTHER - I guess you did because Adrnyalyne figured out what was causing the problem
Reactions: flamingoezz
There is your problem.
ohhhh..is there any battery percentage safe to use with this? i had one for dl30 that worked fine...but that wasn't voodoo. if battery percentage will work for non-voodoo i may end up doing that.
note: my dl09 install prior to upgrading to eb01 isn't voodoo(not sure if there even is a voodoo version)..could that mess me up as well?
Not offensive at all, you deserve it, and earned it
+1; you put more effort into this than Verizon or Samsung combined. You should be seeing some benefit besides a million "lol xyz is brokenz" every time you post an update. Keep up the good work!
If folks find it offensive, I will remove it.
you do great work and deserve to get some kick back. i just snuck you a couple of brews, its not much, wish it could be more. if you tell my wife, i will have to turn of your cable ;)
Your name is fitting, you must run on adrynalyne, just saw you droped 2.3 now!
was just going to sugest that. my phone wnt into a force close thing that only a flash to di01 cured.
Flashed all the way do DI01 came back to 2.3 and still froze. can anyone help??????
Edit: if not, I will just go back to stock EB01 full bloat and debloat myself like I did with DL30.
If you flashed back to DI01 you will need to flash EB01 again before you flash SC 2.x
I did that and I still locked up. I don't know if it is a bad app causing this, but I am going to install the apps slowly and see if one particular does it.
Valentine's Day Hangover Love for my FASN8 and the Devs Who Built It
Hey folks,
I have been waiting to update so that I could release a super clean froyo version for you.
Changes since 2.2:
Added LG's TodayBriefing widget and TodayScheduling widget.
Hopefully uncorrupted audio ringtones, etc. (edit: nope still has issues. Plays fine on PC though....)
Screenshot app is back due to popular demand (its only 21kb)
Hid gps crosshairs.
Added SpareParts. Phone runs nicely with animations and transiitons set to fast.
5 Lockscreen ported by sbrissen with acc battery, slightly modified by me to use ChrisDDD's acc battery icons (blue).
Latest market (2.3.2)
Patch for transitions I forgot on accident: http://adrynalyne.us/files/patches/sc_transitions.zip
Changes since 2.1:
New market added back in.
Modded camera to use power button, credit GizmoDroid
Long press of search works now, integrated into aosp lockscreen/reboot options. Credit dhoard, modified by me. Please note, adw breaks long press of search no matter what. *edit* I guess I was wrong about this.
Debinged EB01 browser by ChrisDD instead of the old EA15 leak browser.
Custom blur animations, credit to calebv2 and whoever else came up with them :p
Added sns back. Should have a minimal, if any, performance hit. Hopefully this cures facebook sync with contacts woes.
Added samsung keyboard back, due to problematic installing after the fact.
Note: Non-voodoo installs have no boot ainmation at this time.
Adrynalyne -
Fantastic stellar work, man! This phone is really rockin' now. Froyo, or as I like to call it cuz I got sick of hearing "where's Froyo?" so many times, "Zengurt" SC 2.3 voodoo (+ transitions patch) is far and away the BEST setup I've had so far. The feature list on this phone now is kRaZy! :)
Mucho thanks to you and the others who helped make this ROM so sweet:
jt: what can one say about this guy
Chris3D: love the batt mod dude, awesome work
GimzoDroid: maybe the BEST mod yet - bringing the Camera button to the FASN8 - i forgot how much i missed that feature in a phone - awesome!
sbrissen - love all the lockscreen options now: i like the rotary and aosp slider. having options rulez!
dhoard - a working long press search!
calebv2 - custom blur animations!
samsung - you gotta admit, they added (finally some might say) some really nice tweaks in DL30/EB01.​
i could go on and on. seriously, when you look at the finer details, and we don't even know the half of it, a LOT of work by a LOT of different people went into making this phone rock like it does right now. Can't thank ALL you guyz enough.
funny how yesterday was VD day cuz man i am loving this phone and all those devs who built it.
to all you Brother Flashers out there, buy these fine folks beers/coffees/whatevers - they deserve it. we're lucky to have them working on our phone.
PEACE OUT :)
is there a way to get the froyo brightness shortcut working on 2.3? i prefer to not have a widget for that if possible
Status
Asad
