[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
try not restoring an app through tb, just re-ld it from the market and set it up that way and see what happens.
Tried that. Still froze. Now, I am removing programs to see if something is not playing nice with sc 2.2.
Still not working.
Edit: Time to go back to DI01 and back up to Froyo.
Still not working.
was just going to sugest that. my phone wnt into a force close thing that only a flash to di01 cured.
Reactions: curley
That is what I am going to be doing tonight. I need this thing for work and right now, everytime I take a call, Black screen of death.
I am currently flashing the EB01 Debloated/Deodexed from the DL30 leak, and just saw the new 2.3 SC release came out. I want to try it out. To make sure I have everything right, I would just download and flash 2.3 SC with CWM correct??
As long as you are also flashing the EB01 modem with the debloated/deodexed rom, you can simply flash to sc 2.3 from cwm with no worries
Is there any way to get Nuance loaded? I needz mah bluetooth for an impending road trip. 1200 miles worth... Flashing 2.3 soon. You are the man Adrynalyne!
Look at the first post in this thread. Scroll down you will see a bunch of patches. There is a nuance-froyo patch
Reactions: 10001110101
i installed the latest voodoo version..seemed to work fine, but when I tried to check out the rotary transition my screen went black, some haptic feedback was going on and it keeps rebooting. any tips?
Sounds like you may have flashed a theme over this. Not a good idea. Might want to reflash rom.
Status
Lassi876
