[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
Thanks, I didn't know that. I thought ROM Manager just backed up the ROM and nandroid backed up the whole phone. So whats the point of ROM Manager?
both only back up the rom. not modem or kernel. rom manager has a neato ui. thats about it. if you boot into recovery you can do multiple flashes of stuff before the reboot. its good for noobs. i used it alot when i first got started. now i jsut cwm.
Cool, I'll just uninstall ROM Manager then. Are you still running SC 2.2 or have you moved up to 2.4?
so i flashed back to DI01 then flashed sc 2.4 thru odin last night and all seemed to be great until i got out of class today and the phone was unresponsive (i had this problem since sc 2.1, but still havent found a fix for it) but now it seems to be even worse in that even tho my phone seems to stay responsive longer, when i got out of class not only was the phone unresponsive but it was HOT!!! I mean really hot like i had been using the phone heavily for days on end....????? plz help b.c it is looking more and more like i mite be headed back to sc .4 just due to this issue... other than that s.c 2.x has been absolutely incredible
flash a theme.
Reactions: bubbadogg14
i think it has something to do with the mic. if you have a cable that has a mic in it it will work.
hmm..i have the standard 2 conductor stereo 1/8" - 1/8" cable. do i need something different to get my phone taking calls while on the dock?
NOTE: calls do not even play through the car speakers..i think they used to without the dock (aux to headphone jack)
yeah, you need a stereo cable with a mic.
thanks Adrynalyne, searching for it now. I love it!
By the way, thanks for making this series of Roms. They are great! Got a score of 1503 on Quadrant. Phone is smooth as silk.
Edit: Don't post links to other forums. Even if the information or method contained within is well founded, it is already here. Now go forth and find it! If you can't, ask. They are here to help.
What issue does http://adrynalyne.us/files/patches/eb01_mms.zip specifically fix with SMS/MMS? If someone can point me to either a specific post here or comment from Samsung. Also, is it already in any of the SC 2.x loads?
Thank you in advance,
SuD
No fix, just restores the stock "samsung" version of the MMS app instead of the AOSP version. People's tastes differ; if you dont like the one out of the box in SC then try the stock one.
Reactions: standupdad
Status
robe3123
