[ROM]Superclean 2.8!! *UPDATED*
Status
Not open for further replies.
I also have seen this where you hit the power button but i see it on stock EB01 so it must be samsungs coding and nothing to do with superclean,,i never said anything about it because i assumed it was just a leak bug and it most likely will be refined in the official build
I can live with it but thought maybe it was an issue with the screenshot option I thought was added by the devs around here. All is good if you guys can get the battery life back to previous builds things will be great.
I do think I have found one of the issues with the battery. I am on about 48 hours right now with my phone between charges its at about 5% right now. I just noticed the gps is off....
I'm running sc 2.6 it my battery life seems to be the best I have had with this phone. I took the phone off charge 10.5 hours ago used the music player for 2+ hours checked email, a couple calls and several text messages. My battery still at 85%. Thanks again Adynalyne
I dropped 20% after 5 hours of pretty much no usage on SC2.6 with the voodoo dummy kernel and on wifi. I'll leave GPS off tomorrow and see if I notice a difference.
Anyone using BT? I got a new a2dp headset Saturday. I tested it a little with the deodexed/minimal debloat EB01 and now with SC 2.6, I can connect anymore.
I assume we can use the JT's new voodoo/non-voodoo kernels with the full odex/deodexed version? Kind of wondering if loading the full unrooted EB01 stickied on the forum and starting over would help? I did notice a few things that were not deleted from the deodexed version when I flashed sc 2.6. maybe that is it?
Can someone confirm BT working?
Six hrs in and down to 9%, S.C. 2.6 NV. Honestly this has been about what I've been getting since dl30.
Every time I flash a ROM since 2.4, I have to re-Odin the new-CWM. That's annoying.
it just doesnt go directly into red recovery because the kernel gets replaced by the stock kernel , so you need just to apply sdcard:update.zip as long as you have the update.zip on your sdcard.
check this thread out [Q] EB01 - Bluetooth issues? - xda-developers
i was having issues connecting to my car and this fixed it for me
Status
nafizahp3
