[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 1.3 [OFFICIAL] ROM
My battery life seems to have gotten worse recently (since the latest rom update maybe???). When I look at my battery stats it seems that the majority of the discharge is split about evenly between the Screen (17%), Android System (17%) and Maps (17%). My phone has literally been sitting on my desk connected to WiFi for most of the 8 hours it has been discharging.
I don't ever remember maps using that much battery when it isn't in use. Anyone else notice the same thing? I am trying to figure out what may have changed that is affecting my battery life. I'm not sure if it is related to the rom update or not.
Is Google now on?
Dazed or Skunk, can the twisted pink theme be used on WS 2.0? I got my gal the GS3 for v-day and rooted it for her. I know she would like the that theme, just hesitant to install without being sure its safe. In the kuban updater it says the theme is for version 1.3. I have been following you guys on here and have been learning alot from you two.
If you flash wicked 2.0, I'm pretty sure the twisted pink theme is available in the Kuban Updater app.
Its in there but says for version 1.3, was curious about using it on the 2.0 version.
So far: Exported from iCal as an ics and then imported into Google Calendar online.
Snoogins. Have Calendar on G1.
Won't sync with iCal, tho.
I also tried copying an iCal shared URL and subscribing in Google Calendar online, but was told it wasn't compatible...?
It's all dazed....
Thanks much Skun... I found the clear memory option
I did check it last night, and still there... like theres a lag when typing
I also check the following to see if it change anything: Settings - Language and Input - Default is set to Swype but underneath that it shows Google voice typing is check mark and Swype is also checkmark but gray out
Where can we look to see when Dazed releases a new ver. of this? I stumbled on v2,
I just want to stay current, and I don't think new complete versions show up in the Kuban? :)
Thanks
Thanks
It's in the op... I thought the updater would have notified you if you have it turned on in settings. There is a new theme that I need to post tonight.
I will be posting a new rom update, nothing major, but you will need to update to keep using the updater. I plan on having the rom and all 3 themes updated tonight.
Hey, just curious and wanna make sure I don't miss anything, did the update come out last night?
ROM UPDATE!!!
Wicked Sensations 2.1 - DOWNLOAD HERE
Twisted Pink for 2.1 - DOWNLOAD HERE
AnaKonda for 2.1 - DOWNLOAD HERE
And NEW Theme for Wicked Sensations "Up in Smoke" - DOWNLOAD HERE
Okay, i did a backup... follow by wipe data factory reset, wipe cache and then davlik... I think it send me back in time to the beginning! Was i supposed to wipe factory reset?
I was following the information from here: http://www.teamvenum.com ? View topic - [ROM]
At the end I did get it to update to 2.1 > but had to start installing all my files back again, games and other updates
Status
n1olan
