[ROM]TeamVenum-Wicked Sensation JellyBean V 3.0 [MB1] ROM
Status
Not open for further replies.
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 1.3 [OFFICIAL] ROM
Keep up the good work Dazed! So how do I buy you a beer? And as always thank you Skunk for your advice and your mods.
Installed 2.1 and everything working great, as expected.
Good job Dazed, as usual. And skunk for posting the update
Re: [ROM]TeamVenum-Wicked Sensation JellyBean V 2.1 [OFFICIAL] ROM
You enjoying the rom is payment enough. Thank you.
Thanks and glad that your liking it.
I updated the Twisted Pink and Up in Smoke theme again tonight. Twisted Pink had an alarm clock issue and Up in Smoke had a superuser issue. Both have been fixed, just follow Skunkapes links. Thank you all and have a great evening.
The new updates dont show up in the Kuban Updater, says iam still using Wicked Sensations 2.0? do i have to download the new update manually or is there a problem with my Kuban?
Thank you!
Thank you!
Read the post above yours. Just follow the links I posted.
The problem with mines is that I was coming from 2.0 ... Didn't need to go thru Wipe Data Factory reset, which I did
Ohhh...should include the original post.
Coming from v1.2 and flashing 2.1. Wondering if I need to do a factory reset or not.
Thank you.
Thank you.
Wipe cache, dalvik, data factory reset as is written in the 1st post.
See below:
-DOWNLOAD THE ROM ON YOUR COMPUTER & TRANSFER TO YOUR SDCARD FOR BEST RESULTS
-ALSO DOWNLOAD THE LJ7 FIRMWARE/MODEM AIO FOUND HERE IF YOU HAVEN'T ALREADY
-BOOT TO RECOVERY
-DO A NANDROID OF YOUR CURRENT SETUP
-WIPE DATA FACTORY RESET
-WIPE CACHE
-WIPE DALVIK CACHE
-GO TO THE ROM AND FLASH
-GO TO THE FIRMWARE/MODEM AND FLASH (IF YOUR ALREADY ON Lj7 MODEM SKIP THIS STEP)
-REBOOT AND ENJOY
That's what confused me a bit... I was coming from 1.3 and went thru: Nandroid, Wipe Fata Factory Reset, Cache and Dalvik
I was able to update but once phone boot it up, I have to basically install all apps
Do the updated themes include all of the updated google apps? or do I need to flash those updates as well?
See below:
http://i.imgur.com/Qqx0w.jpg
-BOOT TO RECOVERY
-WIPE CACHE
-WIPE DALVIK CACHE
-REBOOT AND ENJOY
Thank you guys for the fantastic help!! One clarification question though... It's failing to do a Factory Reset at the moment. I assume this is because I have a work email account on my device and it has been "encrypted." I did see that I am able to do "Format Data" but didn't want to do that before asking. Consequently the encryption isn't allowing me to create a backup right now either. Thank you in advance!
Can you remove the work email account, then do the backup, factory reset and flash, and then reinstall then recreate the email account?
I was thinking along those lines myself. Was wondering if you had titanium backup pro which will backup everything including the settings and login info. You could possibly remove it and restore it. But then again I don't use exchange so I'm not sure.
You really don't want to do the format data as it will erase everything on the data partition including internal storage.
If I were you I would try just wiping cache and dalvik. Leaving data alone. If you have issues just restore your nandroid. It's not the recommended method but sometimes you have to try.
Any time you do a factory reset you have to reload all your apps.
Hi.. a couple weeks back i updated to 1.3 - now in the process of updating to 2.0... If I'm reading all the post in here, I must first do a Nandroid, then Wipe Cache n Davlik, then Flash correct? Just dont want to go thru a Factory Reset. Thank you
That's fine, if that's the way you want to go. I flash dirty quite a bit myself. However if you have issues, don't bash the ROM or complain about issues you may be having. :D
I mean, just wanted to know if I'm coming from a previous version do I always have to Factory Reset. The reset is a given every time I update to new version of Wicked?
Status
marik999
