[ROM] TrulyEpic Rebirth v1.5 AC - no planned EB13 update :'(
pretty much the same, after clearing the camera cache/data immediate fc when I choose sports. Everything else seems to work ok.
Edit: noticed that after screen timeout after testing the camera I cannot get back into the phone. Black screen, capacitive buttons not working. Pressing the power button causes the buttons to light up for an instant. Happened each time I follow that sequence so far. Holding the power button does nothing, soft reboot works. I've never used the camera that much so I don't know how long that has been there.
Hmmm... I'm at a loss on this, possibly Ragnarokx will have a crack at this when he checks in sometime later today... Don't give up hope!
The first thing I would try is flashing camera.apk from stock (deodexed of course) DK28. Perhaps if you get a chance today you can test this out for me Paul as I won't be able to get to it until tonight.
Hello to ALL,
Is there anything i can do to get that feature "Power button ends call while on the phone" back.
Just upgraded from v1.2 to v1.5.
Thanks in Advance for the help.
Cheers,
Cybereg
Exactly what i had to do to get my phone back to work is softrebooting, same blank screen ect..
Had the same thing happen last night
Does anyone have any ideas on why the Display is taking up 90%+ of the battery when I go to the battery use page?
I'll search around a bit more, and just use my phone as normal..
Just set everything up last night, and I noticed it happening then too...
Nothing to be worried about? I just like to check that page a lot.. Perhaps it's broken now?
Thanks!
Strange, I seem to have lost 4G. I cycle between 'Scanning' and 'Disconnected'.
Overdrive here is connecting to 4G fine...
Resetting permissions and rebooting, same thing, "4G Network Disconnected" scrolls and still nada.
I'll try TER v1.5 clean 1st, if I need to go back to v1.2 do I need to Odin to 'true stock', or 'stock DK28' and re-root first?
LOL! I also have action mode switching to panarama mode! I never use Action mode...will wait to see how it gets worked out.
Is there any way to kill the Geotagging in the app like the old camera? I don't understand why they would remove that option from within the camera settings.
To go from TER 1.5 to TER v1.2 just wipe 3x and flash TER 1.2. No need to do anything else.
Paul it didn't work. Do you have an edify version by chance?
Also looking for mIUImusic player for the TRULYEPIC1.5
Thanks,
Cybereg
crayzeefoo
