[ROM] Warm Z TwoPointTwo [RLS1][2/23/2011] Re-Engineered Nightlies [3/12/11]
everything else about this rom is great except for the fonts ,the size is tiny any suggestions ?
In the optional downloads he has the stock fonts and a few others. Not sure if the size changes but you try flashing those.
Is anyone having an issue with voice mail? I can't access it from the phone, but if I call from another line and enter the password it works fine.
Anyone know If we can flash this rom with 3x clockwork yet?
I have been hoping to try this once the Dev patches it to flash w/ 3x clockwork
Ken
Ken
i am using 3.008 to flash it. there is two different downloads from incubus. one to use cw3x and one for older recoveries. hope this helps.
Has anyone been able to get hulu installed? I got it to work with RA_recovery but didnt back that one up before I installed something new and had to do a new install.
I have wiped all three 3x.. flashed the rom. started the phone up and then booted into recovery straight after phone fully booted and flashed the hulu zip and still nothing. wiped and flashed and restarted and flashed hulu fix without wiping and still nada.
Edit:
Could it be that I am using cwm3.008?
2nd Edit:
I got it working. Clean flash of the rom. Booted phone. Went into recovery and flashed fix. Opened astro and I have the Incredibily Re-Engineered Rom zip file on my Sd card so I went into sdcard/"incredibily_re_engineered.zip/data/apps/hulu.. installed and ran the app and viola it works
Do you have the download link for the 3008?
Upstreammiami only posted one download link in the beginning of this thread and I dont think that is for the 3x
Thanks, Im hoping to try out this ROM over the weekend. I do hope its stable w/ everything working.
Ken
Ken
I am using Rom Manager so im sorry but I dont have the download link.
check here - not positive that is the right one for the phone though.. im still a noob
http://forum.xda-developers.com/showthread.php?t=893248
I'm getting alot of force close issues. Gonna try and wipe everything again and reload it again. Hope it works cause the little I got to play with it its smoking fast.
alright so one question i did everything i needed to do did a nandroid back then wiped data/cache and then dalvik installed the rom rebooted phone how long is it ussually on the white htc incredible screen?
Mine booted normally just spent a few minutes at the loading screen (the one in the rom, the marble spinning).
ladakh
