[ROM] Warm Z TwoPointTwo [RLS1][2/23/2011] Re-Engineered Nightlies [3/12/11]
3/5 Beta
This is a beta test. I dont want to add these APK changes to the nightly repository until I get them tested.
Working with WoZZeR999, was able to re-engineer and optimize all apks.
Thanks WoZZeR999 for all your help doing this for me.
You should see a nice speed boost.
Let me know your findings
# Re-Engineered All Apks
# Optimized All Apks
# Added Ziggy 1/21 BFS HAVS Kernel
# Updated Google Car Home (Thanks Robbsta)
# Fixed Lockscreen Pin Numbers Being Unreadable
# Added Warm Themed Market 2.3.2 (Thanks Nils)
# Updated Gmail to 2.3.4.1
# Updated Rom Manager to 3.0.1.0
# Updated Google Maps to 5.2
# Updated Wireless Tether to 2.0.7
Warm-Z-twopointtwo-3-5-11-Beta-By-Incubus26Jc-CWM3.zip
CWM3 only.. (cwm2 users can replace the meta folder in the zip with cwm2 version before flashing if you want to try it.)
I'm getting alot of force closes. Gonna try and install it again. Wiped everything before, and gonna try again.
The first time I installed (tried) it didnt fully wipe even though I wiped all three (twice). So I rebooted into recovery and wiped all three again (twice) rebooted into recovery again and wiped all three again and installed.. Worked fine and so far all is glorious in the android world (atleast in mine)..
Hope this helps
Couldnt tell any speed differences but had multiple freeze ups and reboots. Finally had it freeze up and go black. When i tried to wake it up it did nothing. Pulled the battery and tried to turn it on and got the 5 vibrations. System Restore it was. Wont leave warm Z though.
ok didn't understand the last part ?
about leaving warm z? sorry i meant I will be sticking with Warm Z rom. just went back to my backup. the only issue i have on that build is constant syncing. I cant find which app/widget is doing it.
I noticed the same thing and mine was Facobook contacts. Go menu>settings>accounts & sync>then open each account while its syncing and it will show which one it is. Then just adjust the update schedule.
Only thing that is bugging me about this ROM is I always charge my phone in the car and with this ROM if I turn the car off before I unplug the phone it will require a bat pull or it will just reboot. Anyone else notice this? Sorry if it has been mentioned before :-!
Crazy thing is all of my stuff was set to no less than an hr sync each. I actually think it was something to do with my exchange account.
Has anyone had issues using Titanium when restoring? I want to make sure that wont cause any issues. I have used the backup restore batch function each time I install this rom. I havent seen any issues just double checking myself.
I have not noticed anything to do with turning the car off before unplugging but I will specifically do that tonight. My only other issue is the proximity sensor turning the screen off and not letting it come back on sometimes during phone calls.
Still by far my fav rom. Friend has the At&t inspire and was like look I have new sense 2.0 and im like looook Ive had it longer.. bleh
I love this rom. Work is awesome. I havent stayed on a rom this long since before I rooted. Usually I switched atleast twice a day playing with them.
I do want the thunderbolt when it comes out though. wish they would quit screwing with the release date
I anyone having issues waking the phone up. I've had random reboots and sometimes my phone won't come back on. I have to do a battery pull.
Sent from my Incredible using Tapatalk
xembdttxllink
