[ROM] Warm Z TwoPointTwo [RLS1][2/23/2011] Re-Engineered Nightlies [3/12/11]
Im feeling nice today...
Here is a link to the nightlies directory if anyone wants to test.
These are compatible with CWM2 only....
If you want to use CWM3, unzip and replace the attached META folder in the rom zip before you flash it.
Index of /Nightly
Running the 3-30 nightly now, its so much faster than the current release! The nightly's made me come back to this Rom. Your work is greatly appreciated!
Been Running the 3-30 Nightly for a while now
quite a few random reboots and some power downs that require battery pull for reboot. is this normal?
Decided to jump from CM7 nightly and give this a try.... SWEET FREAKIN ROM... Great Job UpStream for linking this from XDA ;) for real...
No issues at all so far :)
I was a CM7 dieHard for a while until today... I really Really REally like the new sense 2.0 ALOT.
Also.... ANY chance we could ever get a sweet splash screen to go with this ROM :) wishful thinking ;)
Hello all
I just flashed this rom a minute ago, I keep getting error messages about all sorts of processes stopping unexpectedly:
Sorry!
The xxx (process xxx) has stopped unexpectedly. Please try again.
Also there is no background and the calendar/music apps dont seem to have placed correctly. Does anyone know what might be the issue? Should I try to flash again?
Hello all
I had to do a full wipe 3 * in a row just to get this rom to work, and also you need to read the first page of this post all the way through. I was having similar issues like you are having right now, I would love to offer you some more help but I can't right now because I am not at my computer. And god knows nobody ever respond back to anybody in this thread so I will try and help you out later tonight okay buddy :-)
-Via Tapatalk on my hINCm7
Hello all
were you able to get this working for you?
I will be checking this rom out after i get off work. I'm a diehard cm7 like u Seth. I hope u convinced me good
Android, the best community. Sent using tapatalk!
Well.... It cant hurt to try :) I just really like the new sense 2.0 and Camera goodies, plus I KNOW you Need 720p for your guitar recording... just nandroid your current ROM, Do a full wipe of Data, cache, and Dalvik.... Then Flash away my friend, Just PLEASE read the first Page of this thread very carefully before you pick which .zip to Flash. it makes a difference which CWM your running for some reason. Let me know How it goes. Here is a SS of my homescreen now.... (not that it matters:)
Nice Seth a I like it alot just by looking. And yes 720p for my GUITAR! I always flash stock and then take bids go back. Kinda a hassle.... going to read read read now. And I just updaded cwm yesterday so I have latest version don't know if I shoulda nit have updated.....
I am running version 3.x of CWM and I had to do a full wipe twice with .zip flash, then finally everything was working right :) the first time I flashed it, none of my google apps would work; So, all I did was just repeat Full wipe of everything and reflash of the "correct" zip and it worked great. then it took about 30 mins for titanium to reload all of my apps. I was/am a DIEHARD CM7 guy too, but I just really like the new sense 2.0!
Also, I am getting pretty much the same battery life as I was on CM. have you ever used setCPU app to control your kernels, becuase this ROM has one of chads baked into it and you need setCPU if you want full control of it.
Again, you know the drill ;) any questions, just ask... also, if you find that you NEED any info immediately, you can always check out XDA forums... the only downside about them is there is ALOT of clutter because there are so many people there; but you will always find the answer if you dig a little bit. thats the main reason I stick around this site; less clutter and people are more respectful.
Reactions: kaefbaml
Ssethv, do you need to install RLS1 first then upgrade to the nightlies or just go for it on the nightlies? I'm coming from CM7 also so I can get a look at the new sense.
im about to wipe everything right now just did a nandroid and i think i want to get titanium pro, because i dont want to spend like 4 hours d/lin and re setting every app back up. so i might be purchasing that app real fast...
ALSO, in regards to your question in the other thread about syncing audio... I just ran some tests on my phone (with WarmZ of course)...... RESULTS -> there is slight lag between audio and video when recording in 720p, HOWEVER, when I changed the setting to widescreen, audio and video worked in perfect harmony; and I didn't even notice a diff in vid quality. Also, you will be surprised at the effects you can do in Camera or Camcorder MODE :)
you don't need to buy it just to save your apps :)
I don't think so but you do need to be running a 2.x version of CWM to run the nightlies... just click on the nightlies link on the OP (its not a zip) it will explain it a bit more... :)
Just DL the free titanium, open it, then select Backup/restore (top of screen), at this point you can go one by one and back up BUT make it easy on yourself, hit the menu button (on the actual phone itself) then select batch.... there will be ALOT of options, I chose to just select "backup all user apps" ... this will save them to your SD card, then when you do a FULL WIPE, go to the market redownload titanium, select restore (top of screen) and choose batch again (or one by one if you want) and restore apps. Good luck bro :) happy flashing
Got it, thanks.
One more quick on, it says to flash the older cwm version and it would temporarily give you 2.XX to flash the nightly. Then when you reboot you'll be back up to 3.XX. Does that mean I should put both on the root of the SD card? I thought having more than one zip on the root would mess up the flash.
My current plan is to put both on the root, flash the older cwm, then flash the latest nightly.
Got it, thanks.
you can put what ever .zip you want on the root of your SD card (youd laugh if you saw mine:) the only time a .zip file is recocnized is when you actually flash it in recovery. I have tons of different .zips on my SD card (kernel's, boot animations, splash screens)
Lolipophokya
