[ROM] Warm Z TwoPointTwo [RLS1][2/23/2011] Re-Engineered Nightlies [3/12/11]
...well now I feel like a tried and true jacka$$! don't suppose I could get a link to the nightlies, of downloaded my copy from theincrediblelist.com and they don't have the nightlies, that I've seen.
CWM 2.5.1.2 just keeps saying "removing old system" for a while, then says installation complete. When I reboot, it stays on the HTC Incredible boot screen indefinitely. I wiped data/cache/dalvikcash. Any help?
Lol...
IMMEDIATELY, and I mean immediately after I hit post, it booted. Sorry, disregard, it was definitely CMW 3.x.x.x, after downgrading, it worked. Thanks guys!
its in the op download section
As always still an awesome Rom. I have a new issue. When using my exchange email account and compose a new email it does not allow me to see my contact.
Sent from my Incredible using Tapatalk
I'm really starting to feel like a moron, but I've never had this much troubles with installing a rom. Anyways I have Warm Z running and it's awesome, I even got CWM 2.5.1.2 installed (although for some reason it still says 3.0.0.8 in rom manager), now I just need to get the nightly to install and run .
Ok heres what I'm doing, please let me know if I'm just a moron like I'm starting to feel. To start I reboot into recovery, wipe all user data, wipe cache, and wipe dalvik, I then tell it to install the newest nightly that I downloaded which it seems to do just fine. The problem lies in the boot afterwards, it loads the white htc screen and never moves passed it. I've tried 6 times and every time same result. Just incase it's asked I've been waiting 10 plus minutes on the screen before pulling battery and trying again.
Any help as usual is greatly appreciated.
after you do all wipes you click on install zip from sdcard/ choose from sd then locate the rom ....
also make ur downloading the right file not the supersonic one
$#@& well that's my problem I downloaded the supersonic....well I'm just gonna have to wait til next month then cause I don't have internet I do this all on my phone and I'm pushing 3.2 gigs already and I still have 20 days left on billing period.
Upstreammiami..
I see the linkl to the google codebase...
I am looking fro the actual link to the ~200mb file that would include all the fixes up to R108... Am I missing something on the google page?
Yay I'm posting another problem lol!
This isn't to big a deal, only about twice a year when I go to canada lol. Anyways the problem is whenever I try to to open my "mobile network" settings it just force closes and reboots my mobile connection. Basically I need the ability to turn my roaming data on and off and can only do it in the settings, wireless & networks, mobile network. Plus it's always nice to just have everything working.
has anyone figured out a way to change the font for this rom?
**nm, got it downloaded off the xda site**
Is there an optional download for verizons backup assitant? I didnt see it anywhere.
I just flashed this rom last night, Im not doing the nightlies, But I do Love the new sense.
I have some digging around to do for tweaking.
I have used Titanium to freeze the usual stuff to save battery, I have noticed allot of new stuff when scrolling through Ti. I will need to figure out what they all are.
Ken
ok so I see the post from upstreammiami for downloading the new market to fix the market. I cant get into my sd card, when I plug in the phone to my comp i dont get the pop up to load as disk drive.
How do I fix this so I can place the new market dl on my sd to flash it?
thanks
Ken
Awsome ROM, best one yet. However found a major glitch.
In Contacts or People there are fields missing. There is no Mobile or Home fields. So when you have favorites Widget setup and you try to set a default action for a person, your only choices are Call: Work, Work Fax, Home Fax, Pager, other, Callback, and car. Same problem when adding a new contact, there is no field for Home or Mobile.
Thanks again for all your hard work and awesome ROM!!
Love the Rom, having two issues
1) Can't get to any Sound options (ringtone, notification, etc) ... I can get into the Sound panel under options, but if I tap on anything that would bring up the list of sources (music, built-in, etc) "The application Sound set (process.htc.sdm) has stopped unexpectedly." and am left with a Force Close button.
2) Is anyone else having issues with Exchange sync and contacts? Mine are fine for a day or two and then, bam, sync error ... only way I seem to be able to recover sync is to remove the exchange account, wipe data from Contacts storage, restart the phone and re-add my Exchange account.
I was on the 2/23 RLS, but have been flashing nightlies in hopes that something would change ... but I'm getting consistent behavior from them all (unfortunately)
Thanks much in advance!
Can you help me figure that out, I'm not a member there and a noob at this so far...
** Also, after doing the data throttle removal, I can't seem to connect to any WiFi networks now ......Help please
Am I supposed to be able to do a regular PRL update with this Rom or does it block that? When I call *22899 it doesn't do anything anymore ....
I gave up and restored my stock Rom for now.
Does anyone know why the WiFi tether didn't work or why I couldn't update my PRL?
I really liked the Warm Z 2.2 but the font was so small and didn't word wrap when I tried reading on the internet ...bummer !!
