[ROM][WIP][PORT]Paranoidandroid from optimus one to optimus s
This isn't going well at all. For some reason Repo is having trouble cloning the ParanoidAndroid sources. If all else fails, I'll attempt a report of the CM9 version with the Optimus One variant.
Apparently, when one ports ParanoidAndroid, one requires a version of libandroid.so, libandroid_runtime.so and libandroid_servers.so from a version of ParanoidAndroid of the same processor arch. So in order for us to port CM10, we'll have to find an ARMv6 version of ParanoidAndroid that we can boost the libraries out of and pop them into /system/lib. Then the port should boot. Should I put up the non-booting package I have for anyone who wants to play around?
Reactions: jonny5449
Jonny says yes
Sent from my LG-LS670 using Tapatalk 2
Jonny says yes
Loool. You made me think of Johnny Bravo. :p
@Shadow, if you port using CM9, you will have to reconfigure the build.prop to get paranoid stuff working. You would most likely do better than me, I couldn't start to do it. To confusing :P
Crap, Jonny, I'll have to find my other ZIP I made, was gonna upload it and it looks like I deleted my workspace to regain space. Also, ThatGuyLurking, Thanks for the tip :3 The build.prop is the first thing I change because it bugs me to have phones identifying as another (especially when it causes the market to go nuts and display things that are either incompatible or not display ones that are.).
Thank u sir
Your basing it off CM10? o-o
Ya, if I didn't need to compile an ARMv6 version of PA's libandroid_runtime.so and related libraries, we would've had a working PA 1.9.5 ROM. The new versions of PA are implicitly based off CM10.
Sent from my LG-LS670 using Android Central Forums
I updated my Port, still CM9, wanna check it out? :)
Reactions: ShadowEO
ali5505
