ThatGuyLurkin
- Jun 4, 2012
- 2,155
- 665
- 0
Go question UnknownArtist. He has an idea for it. Honeycomb sources were released too.
Sent from my Triumph using Tapatalk 2
Yaaaaaay people care!!!!:beer:
Sent from my LS670 using Android Central Forums
If this Rom was good n stable I'd use it it would probably be my favorite
plus flash
Did this ROM completely die? Would love to have a version based on CM10. :3
I asked the port author for our OptiS port and got no reply so not sure.Okay say I got cm10 and paranoid and I wanna incorperate the tablet.ui and whatever what are the main framework differences?
Now remember paranoid android was ALWAYS cm9 I highly doubt it would work
Sent from my LG-LS670 using Android Central Forums
It does work, I saw a ParanoidAndroid CM10 ROM on XDA the other day.
I can attempt on free time maybe
If person says yes point me too it also it will be hard if this
Not 600mhz prossecer
Lol
Not mdpi
Not cdma
That will be hard but supposing I get drews or zakmans cm10 I can pull the files from this and put in cm10 rom and it should work
I mean I asked the author of this port (Op), no reply at all. Also, tomorrow while I'm at work I'll post the link to the CM10 ParanoidAndroid Port.
Ok, just got to work and here's the links
Official Porting Guide for ParanoidAndroid
ParanoidAndroid/CM10
I'd assume you'd follow the first link and then just use CM10 as the base instead of CM9
Ok, I just asked the port author permission. If he says Yes, I'll be sure to update this post. I also asked Drew in his CM10 thread. This is so exciting because the screenshots of CM10/PA look amazing.
its going to be hard not a 123 thing because its not mdpi but i will try no promisis
No worries, I'm gonna try it in my spare time as well. If one of us gets a reasonably working ROM, we could help each other. I haven't built from source yet though so I can't say I'll be very good in that sense.
Edit: I'm gonna search for another Hybrid and try to find a MDPI version. Though it is said that ParanoidAndroid is DPI independent.
There's this one as well.
Ok search for mdpi one and sure would love to help each other but damn started making pad.prop from that rom oh well
The pad.prop should be fine on any ROM. It's just the DPI settings for the apps. Which is why I don't think we'll have to worry about it.
EDIT: Just got a message back from the Author. LET THE PORTING BEGIN! (As soon as we have Drew's permission of course)
I'm compiling the ported framework-res.apk for the Optimus S right now. I should have this done by the time I leave work and can test it out :3
