[ROM][WIP][PORT]Paranoidandroid from optimus one to optimus s
Also the pad.prop is screwing me over right now instead I took a break and updated godzilla I'm a amateur lol:p
kinda weird but looking for good keyboards????
visit my sight
jonskeyboards
As am I lol (an amateur, I mean.). For some reason, I'm getting a bunch of errors after decompiling framework-res.apk with APKTool. I even updated my platform-tools
Edit: Alright, I'm gonna try something I know I shouldn't. I'm gonna use the Framework-res.apk for this version on the CM10 one since this one already has the device specific XML in it (I'm gonna use it as the modified one that I merge with the PA one.)
its going to be hard not a 123 thing because its not mdpi but i will try no promisis
Actually, its doesn't matter if its MDPI or Not. Paranoid Android IS ported from HDPI/XHDPI. The one i ported from the Optimus One was ported from the Nexus.
Exactly but easier because YOU didn't port the nexus one you ported the optimus 1 one
visit my sight
jonskeyboards
I'm flashing the first test ZIP now :3 Let's see if this works lol, I used the res folder from the PA framework-res.apk found here. If it boots we can try to fix that afterwards as long as nothing to major is broken because of it. So far it's booting. I think APKTool is decoding the JB files wrong, I updated my platform-tools (hence aapt as well) and I still can't compile the modifications correctly.
Edit: Bootlooped. Trying something else.
Not working. I get this everytime I start.
Code:
E/AndroidRuntime( 2239): *** FATAL EXCEPTION IN SYSTEM PROCESS: android.server.S
erverThread
E/AndroidRuntime( 2239): java.lang.UnsatisfiedLinkError: Native method not found
: android.util.ExtendedPropertiesUtils.readFile:(Ljava/lang/String;)Ljava/lang/S
tring;
E/AndroidRuntime( 2239):        at android.util.ExtendedPropertiesUtils.readFile
(Native Method)
E/AndroidRuntime( 2239):        at android.util.ExtendedPropertiesUtils.refreshP
roperties(ExtendedPropertiesUtils.java:301)
E/AndroidRuntime( 2239):        at android.app.ContextImpl.paranoidInit(ContextI
mpl.java:1592)
E/AndroidRuntime( 2239):        at android.app.ContextImpl.init(ContextImpl.java
:1704)
E/AndroidRuntime( 2239):        at android.app.ContextImpl.createSystemContext(C
ontextImpl.java:1561)
E/AndroidRuntime( 2239):        at android.app.ActivityThread.getSystemContext(A
ctivityThread.java:1899)
E/AndroidRuntime( 2239):        at android.app.ActivityThread.attach(ActivityThr
ead.java:4815)
E/AndroidRuntime( 2239):        at android.app.ActivityThread.systemMain(Activit
yThread.java:4854)
E/AndroidRuntime( 2239):        at com.android.server.am.ActivityManagerService.
main(ActivityManagerService.java:1370)
E/AndroidRuntime( 2239):        at com.android.server.ServerThread.run(SystemSer
ver.java:171)
I/Process ( 2239): Sending signal. PID: 2239 SIG: 9
E/AndroidRuntime( 2239): Error reporting crash
E/AndroidRuntime( 2239): java.lang.NullPointerException
E/AndroidRuntime( 2239):        at com.android.internal.os.RuntimeInit$UncaughtH
andler.uncaughtException(RuntimeInit.java:76)
E/AndroidRuntime( 2239):        at java.lang.ThreadGroup.uncaughtException(Threa
dGroup.java:693)
dGroup.java:690)
OMG, I just found the updated JB APKTool. Gonna try with that.
Code:
erverThread
tring;
(Native Method)
mpl.java:1592)
:1704)
ead.java:4815)
yThread.java:4854)
ver.java:171)
dGroup.java:693)
dGroup.java:690)
That will most likely help lol:D:D
visit my sight
jonskeyboards.Wordpress.com
It's not, for some reason I can decompile, but it won't let me recompile without throwing errors up.
That's dumb are you following that one guide I have my doubts because its cm9 so ya but its still work in progress I was thinking couldn't you use parts of this rom help make it???
visit my sight
I got the framework-res.apk compiled despite the errors but I still can't get the ROM to boot. I'm gonna ask on their forum.
visit my sight
The guy from the p500 forum USED the same files from the Nexus the same way I port. And the Nexus One, no. The Nexus 4G I believe.
It makes it no different. Trust me, I know more of this than you. Gannon, Anthony, Sellers, etc, they told me it doesn't matter. As long as the apps are right.(I may be wrong, couldn't find post)
Oh
visit my sight
jonskeyboards.Wordpress.com more than 50 downloads in the first 2 hours
Well man im "rooting" for you!
(pun intended)
Sent from my LS670 using Android Central Forums
Well, I got the framework-res.apk to compile correctly, but I'm still getting that logcat bootloop error that I posted earlier. I asked for help on their forum and PM'd one of the lead devs to see if he could help me solve the problem, but I can't for the life of me figure this out. I'm gonna dive into their github here in a few minutes to see if I can find what ParanoidInit is trying do.
Why are you decompoling framework? o-o
Are you using the 2 files in Media?
Was following the ParanoidAndroid porting guide. It calls me to merge device specific entries in the framework-res.apk with the ParanoidAndroid framework-res.apk.
Found what's going on,
I was talking with one of the devs and he told me I needed a libandroid_runtime.so from the ParanoidAndroid ROM. So I'm gonna try building a generic PA ROM from source and copy it out.
Cool
visit
jonskeyboards.com
Ok, I'm reinstalling Ubuntu as a 64bit OS now so I can build a generic ARMv6 ROM to copy the files from.
BeshevGames
