ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
Even my experience varies with this issue. And also it started with stock rooted. We will look in to it and see if there's any way we can make it better. No promises though.
Yup, reflashing works... I guess I had the old Gingerbread update zip in there and I accidentally flashed some parts of it by accident. hahah... :) Thanks again.
I've got a problem. I had RebornRom, copied YouMom Rom to the SD card, made a backup, wiped everything and installed the new Rom. Phone boots up fine, but it cannot find my Sprint Mobile Network and I can't get back to recovery using "adb reboot recovery". It simply reboots the phone.
I just noticed I haveBaseband version: LS670MVH and SW Version LS670ZVH.
Does anyone have advice?
Just got this rom and I really like it but I am having trouble downloading from the market. It keeps saying I have insufficient space which is incorrect since I have over 100 MB left. I have tried clearing Market data and using the marketfix app. It seems when i uninstall market updates it works but then after downloading one app it stops working again.
Yes, you need to update to baseball ZVH, aka Gingerbread. In the stickies at the top of this page there is a link on rooting ZVH, within that thread there is
another link on how to upgrade.
Did you do a complete wipe before flashing this Rom? I suggest you wipe data and all caches then reflash the Rom and start from scratch.
Thank you! Will do that now. I did get back into recovery and did a restore.
Yes I just upgraded from ZVD baseband and wiped everything. Would rewiping and flashing again really solve this?
I have a bit of an issue. After flashing Rom, full data/cache/David wipe, I can't open music. I keep getting .processcom. android. Musicforce closes. Any thoughts
Ok, will try this tonight. Will not wiping the data still keep my apps and settings in tact?
Yes it will keep all that intact, but that was my reply to the post above mine about Music. Your issue may not be solved by this method. Worth a shot. If not then I still recommend a full wipe.
Reactions: ascooney
silly question, but I'm probably going to upgrade from reborn to your mom soon and noticed app2sd wasn't supported. I have it on reborn with the app from the market, and it's pretty much the only thing keeping my internal memory from being filled. would that work with this rom?
Reactions: ip_freely
It should work just fine with this rom. If you do experience any issues, just please remove apps2sd and replicate the issues(s) prior to posting about them here.
I have ZVH and just flashed to Your Mom. I like other launcher docks like Go Launcher that have customizable icons (and more than 2). Are we able to use Go Launcher with Your Mom's ROM?
Status
xembdttxllink
