ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
Had it running for 12 hours now, no problems.
I have flashed Drew's latest kernel, and, I too have experienced the SD Card just disappearing. Its not a huge deal, all you have to do is remount it, just wanted to report the bug.
Does the ROM go through the normal "zvh maintenance" after upgrading from ZVD? i have noticed it is a little laggy at times, but 99% of the time it is as fast or faster then kravens or drews cm7 port. again, excellent job to those involved with developing.
If you came straight from zvd, then it would not surprise me if some maintenance is going on in the background at first. It really should not last much more than a day or so.
Glad u enjoy the Rom, going to make some small updates here soon for v1.0. Just a couple fixes, nothing groundbreaking for the new release. This build has proven to be quite stable for the most part.
Re: [RoM] YOUR-MOM-ROM - with POWER CONTROLS ! ! !
Okayy, I've just been tempted to put the ZVH baseband to my Optimus V, and from what I've heard I know I can get it to work. :P
So far so good. Data2ext-v4 modified working just fine. Getting ready to install my buckets of apps lol
Which Data2ext version are you using? The one for reborn or cm7? Thanks
We thank you for that, also make sure you grab Drews new kernal if you haven't already. It makes the sexyness even better.
http://forums.androidcentral.com/showthread.php?p=1205868
One thing to note on that, which I found out yesterday:
Make sure the ROM has fully booted the first time after flashing BEFORE loading the new kernel in. I flashed the ROM and then immediately flashed the v07 kernel and the status bar showed nothing. There were no signal bars, clock, or anything. The phone functions still worked, but there was no visibility on the top bar. I duplicated the issue twice. It was a clean flash both times. So make sure that you let the phone fully boot up, then reboot recovery and flash the kernel. Just my 2 cents.
Reactions: jstntp
Odds are a reboot or two would have fixed the issue you experienced, but nonetheless good idea to go ahead and let the Rom boot entirely first then flash the new kernal.
I have a slightly modified data2ext zip to try if anyone is interested. I'll upload it in a few with instructions.
Reactions: DarkRival
@ Kenny
Glad u tried out your mom. For the tude part it was a one line answer to your strange post. Nothing more. Cheers
Sent from my PG86100 using Tapatalk
Nice work, guys! I'm really excited to try Your Mom, but I'm afraid of the ZVH bugs. Reborn ROM is so stable that I think I'll wait 'til Sprint fixes their bugs.
I'm really glad to see continued development work on the Optimus S. Thanks everyone!
P.S. The name is great!
Does the handset mic work when the headset is plugged in on this ROM? I'm about ready to risk the leap to ZVH sketchiness after seeing this, but I've got to have this feature if I'm going to be using Your Mom for a while. :D
The name is just ridiculous. It's like I'm back in 8th grade all over again.
Your mom so stupid she tripped over a cordless phone!
I so hope that is not true of this ROM. :D
And is this app included in the install?
Your mom inspired the name. I tip my hat to her :p
LOL jk
Although I have not tested it, the handset mic issue is bug from the wonderful zvh update, so I'm going to say no unfortunately.
If someone could verify this, that would be sweet.
Did you change the "Roaming Indicator Flashing" back to "Roaming" and have the triangle not flash?
[INFO]Testing Phase for DATA2EXT is now up in post #3
Please read and follow all directions carefully!!
[/INFO]
Interesting. What's the difference between data2ext-4 modified and the one for your mom?
Nothing crazy, it just moves dalvik back to data automatically and you don't get the errors about there being no modules when you enable it. It's virtually the same script though.
I have been running for a few days and no bugs. The power controls were the one thing that I was really missing. Nice to have them back you guys have done a fantastic job.
As a side note I really like the black google search widget.
Thanks, glad you are enjoying the ROM! I love the black search widget as well :D
Been running several days here too with data2ext enabled, used the old modified before Justin put up the new one. No real problems just the weird glitch where I cant boot into recovery from anything except quickboot. Great work guys keep it up.
Mark
Reactions: jstntp
Just bit the bullet and went from ReBorn to this one.
It's nice, but I'm noticing some things:
Awaiting an installable Live Wallpaper APK; don't like the ability to install them is completely removed. (Much like I don't like your mom)
Also, does your mom plan to put the "recovery mode" option back on the "hold power button down" menu? I did enjoy that a lot in ReBorn; made it easy to make backups. Hate to waste another icon on the screen for a recovery boot.
How would I got about getting the bottom bar to have the 4 icon +appmenu dock? Two icons+appmenu isn't doing it for me (like your mom :) )
Slide down power widgets.. think they could be made in blue like the Reborn custom one?
(like this one but it was blue eventually:
Think that's all for now, but really looking forward to watching this ROM grow!
Excellent work!
i flash the rom and now when i want to move my apps to sd card it says that its full ????:confused:
Status
