ARCHIVED: [RoM] YOUR-MOM-ROM v.1.1 - Updated 11/27/11
Status
Not open for further replies.
Re: [RoM] YOUR-MOM-ROM - with POWER CONTROLS ! ! !
Looks like this will be the ZVH reborn rom equivalent. Has a nice feel and responsiveness, can't wait for next version. Only thing i might question is battery life (lowest brightness, always ending tasks,still going relatively fast). I'm sure that'll improve down the line. But this is great work, the first ZVH rom that almost entirely eliminates the double tapping screen issue. I'd recommend it to people with an optimus
This is going to be the closest thing you get to Reborn. The only reason it doesnt feel the same is because of the ZVH base. I hope they resolve the GB issues soon for the Optimus S. Glad to see you are enjoying your mom. :cool:
Does tethering work well with this rom? Had alot of trouble with it on g rom. I think I got it working once. Really gotta have it for work, and wanna try this. Thanks
Sent from my PC36100 using Tapatalk
one quick issue I run into now that I think about it is ill have perfect data speed, texts sending, but not recieving until a restart. then again this could just be a zvh thing, but figured I'd mention anything I run into for the sake of the rom's improvement
You may also be having service issues in your area. I'd check with Sprint Customer Care and see about that. If they ask you what version of the software your phone is running, tell them "Your Mom" and imagine the confused look on the representative's face :p
This rom is pretty bad azz. I went ahead and flashed it and did the mod in the first post and I must say this is nice. Tried the tether and it works perfectly with no errors. I would like the live wallpapers back though. That and a couple good themes. I'm sure all that will be done in time. Thanks to the developers.
Quick question, I can't find any details on with searching (only a mention in the other ROM's thread):
This is my first foray into the VHD update, and I've noticed the touchscreen sensitivity is all out of wack at times.
It repeats characters (double taps) or holding and dragging seems to think I've lifted my finger when I haven't.
Is this a VHD thing and can it be fixed via software somehow?
Unfortunately this is a zvh issue. It will come and go from time to time. Try flashing the new GingerKernal v07.1, that may help a bit.
Reactions: Enzomatrx
Waiting for signed 1.0 version to flash this weekend...I hope
any chance for a clock mod to put it back in stock position? i roam a lot at work and when the gps icon comes up or sync icon it covers the clock like crazy. thanks in advance.
I'm getting the SOD issue, turned off animations.... Any ideas??
Should I just do a dirty flash??
Thanks
Thanks for the heads up on that. Flashed it now. Glad that it recognized the screen flickering issues at those random frequencies. I was definitely experiencing that, so it's nice to at least upgrade to something that won't do it.
So is there any change of that default LG Launcher being used in this ROM (for the multiple icon dock at the bottom)? Never switched launchers before so I don't want to play around.
@Enzomatrx
launcher pro is the way to go,or zeam launcher
There is absolutely nothing to installing a launcher. You download it from market, just hit home, select new launcher. If you don't like it, hit home and select old launcher. When you decide on one, hit home and check make default then pick the launcher you want to keep. Simple.
yes it is almost constant roaming in my area of Pennsylvania. its a wonder they dont drop me for roaming violations.but the text not receiving hasn't happened since, perhaps it was the background work zvh does after you flash it
and not to sound like the great complainer but i did run into one thing that does repeatedly happen. When recording audio to send to someone, as soon as use this recording is hit, messaging crashes. The same happens when receiving videos, the only fix being to delete the thread for that person and start a new one.
Since you reported this issue I am not able to recreate it. I swapped back to my Optimus this morning to verify. It could just be another intermittent ZVH issue. Either way it still isnt good...
Reactions: matthearnow
Quick question....I am a little new and this is my first ROM that has fully worked... i really like the TSM black alien theme is it compatible??
Status
