S20 Firmware For Odin Flash?
Yeah on unlocked just flash csc from U thats how you get the att stuff
OK one last question i promise. So I should use the 986U1 (att) like the one i used? And then just use the CSC from 986U USA CSC? Sorry as I'm replying I'm looking at the downloads from the site and just looking at everything. Just dont want to screw it up again.
If you you going use 986u then use all its files , if you going to use 986u1 use all the files except home csc use the regular csc , if you use the csc from 986u on the 986u1 you will manual have to update and won't get OTA update.
OK Thank you for taking the time to reply and help me out. Greatly appreciated.
Afternoon. I meant to ask when you say using the 986U will bring back the att stuff would that give me the 5G and wifi calling back?
Yeah the carrier version 986u you get wifi calling and 5g works on both unlocked or carrier it just if your area has it . On the unlocked no wifi calling.
Your welcome!
I'm here to help anytime
Hi. So good news i have wifi calling back. But no 5G only 4Glte. Also still boots with aTT logo. Not sure if its supposed to.
I used the 986U1 for everything but the CSC. For the CSC I used the 986U. The hell i do wrong
I just looked and for some reason i didnt do user data. Was i supposed to?
User data the last slot always ignore,
Boot up with att stuff because the carrier csc you put on odin, as for 5g you have to be in area that has it
Thanks for reply. little confused with the first part
I am in 5G area. Had it before i flashed the files. Havent had it since
I guess the 986u1 is the att stuff? Thats what it says in file name anyway
You mentioned you put csc file 986u on the 986u1 firmware?
Thsts the reason wifi calling and att logo , maybe it messed with 5g I'm not sure
Think I may have found an issue. If im understanding correctly the file for the 986u has a USC on the end of file. From what ive been reading the USC is for US Cellular. If its true I wonder if thats the issue
Thats the csc you used , then yes use att one
Jackwills2567
