Samsung.com Orders
Thanks. My order still shows $200 credit and did not uncheck. Just undecided on what to choose on preorder
JOD isn't what it used to be.
what an understatement! they wanted $850 downpayment for the S20 Ultra 512gb, plus a monthly payment.
that's a whopping 50% of the phone! plus, at the end of 12 months, i won't own the phone unless i paid off the remainng 7 months of the lease!
i got out of JOD as well after being on it for years and years.
Too bad TMO messed up a good thing. There are others who've complained about JOD and how it's gone downhill. Glad to here you've moved on.
Is that for Rakuten?
This is referral code which can be used for new Samsung accounts. There was bunch of this circulating on Reddit. I didn't because I already have my Samsung account and like to have everything under there. But if someone wants to create a new Samsung account and order they can use the referral code to get additional discount.
They may send you a code to use it in the future. I'm not sure how can use it otherwise.
When I did this way for Note 10, my order details specifically said $150 promotional e-coupon and it'll be emailed after the return period ends.
Attached is my Note 10 order details which clearly says that the promotion coupon will be emailed later since I choose not to select gifts at checkout.
Ahhh...the plot thickens.
Yes....I recall something exactly like that. If I also recall correctly if you only used part of your credit up front you lose the balance. I lost 2 cents from my 200....lol
Yes it's one time use whether you decide to use while ordering or later. But once you apply the coupon you have to use all the credit. If one orders $30 case thinking they will use rest later then it's gone.
i believe my 45-watt charger plus the earbuds+ model totaled very close to the $200 coupon that i had to use up in one transaction, and those two accessories are something like $150 and $50, so they are almost exactly $200.
Yes....I ordered the same exact thing and had 2 cents left over. It would depend on your tax rate.
Lol so um does anyone know how long after you cancel an order that Samsung takes to "hold" off that money. I placed an order on Friday with my bank card meanwhile that card my bank cancelled and sent me a new one. Since I couldn't change the payment method I had to cancel and reorder, which I did. Then a couple of hours ago I realized crap I forgot the 10% cash back. So once again I cancelled the order and reordered everything. So yeah know I have like almost 1100 dollars tied up in Samsung holds.
Usually within 24 hrs. for Samsung, but with your orders being over the weekend it may take longer. Also your bank might have its own processing time.
Yeah Wells Fargo was almost instant when I cancelled and had to reorder.
for once, i wasn't that unhappy with zero options for colors!
for the 512gb S20 Ultra, you may have any color whatsoever, as long as it is black, as Mr. Ford said.
well, i'm ok with it. not joyously ok, but ok :P
freddieleo7
