Samsung Galaxy S4: APN Straight Talk settings HELP
Re: Samsung Galaxy S4 APN Straight Talk settings HELP
Hello.Maybe you could help me.I tried so many settings on my S4 but nothing worked.In my s3 and samsung young,the mobile internet but not on my s4. The only difference was the grayed portion APN enabled/disabled is unchecked.What to do? Thank you.
Still wondering how to get lg optimus l9 to work for straight talk with att sim card. Any help please!
These settings worked for me. About 10 minutes ago!
NAME Straight Talk
APN tfdata
PORT 80
APN type: default,supl,mms,hipri
APN protocol: IPv4
APN enable/disable: APN enabled
Bearer: Unspecified
- - - Updated - - -
NAME Straight Talk
APN tfdata
PORT 80
APN protocol: IPv4
Bearer: Unspecified
I have a Samsung Galaxy S4 GT-I9500 and have tried numerous apn settings and can only get edge Internet. Can someone please help me ?
SOME ONE PLEASE HELP ME BEFORE I PULL ALL MY HAIR OUT AND WASTE MORE ENDLESS HOURS PUNCHING IN DATA INFO THATS USELESS!!!!!
I have a GT-I9500 Android version 4.2.2 Baseband Version. I bought this phone from e-Bay and it came from china . I love the phone and regular texts work fine, calls work fine but just cant get the data to work. I need data outside of my home when I have it hooked into Wi-Fi.
Someone pleeeeeaaaaasssssseeeee help me. I live in PA and Ive activated the phone with the bigger size sim (as it is dual sim) couldn't fig out how to activate the mini sim so I removed it.
The initial apn ifo I was given for my area was :
Straight talk
APN: tfdata
MMSC http://mms-tf.net
MMS PROXY: mms3.tracfone.com
Port : 80
and it didn't work. I realize this is a generic version of a Samsung galaxy just not sure what number.
anyone have any suggestions
Im obviously not technically inclined but what is edge Internet?
Hello,, Unlocked ATT Samsung S4 on ST everything works but MMS. Can you help. Jay... [email address removed] Thanks
OK here it is: I need the most current and correct Straight Talk APN settings for an unlocked Galaxy S4 Model GT-19500.
Hello Everyone! I am fairly new to the forum and don't even know how to post a new thread :-\
I have an issue with my Samsung S4 (GT-i9505 with unlocked GSM). I am using the Straight Talk network with a T-Mobile sim. Three days ago, my internet stopped working and I had an icon that says "SIGN INTO NETWORK HOME" pop up... I spoke to Straight Talk customer service and they tried all their tricks, even had me reset my phone only to tell me in the end that it was probably my phone...sigh... I have tried almost everything I've seen posted on the forum to no avail.
Please, if anyone can help me get my internet going again, I would be eternally thankful- :'(
So you have a SAMSUNG GALAXY S4 with at&t micro sim card and the above settings allows mms to work??? I am having a hard time getting mms for send and receive. I just bought a AT&T galaxy s4 and have the ST at&t micro sim card!
This is it!! APN for Galaxy S4 running Straighttalk, Straight talk Don't add anything, don't delete anything. if you don't see a space after a comma or period, don't add one!
APN: att.mvno
Proxy: Not set
Port: 80
User name: Not set
Password: Not set
Server: Not set
MMSC: http://mmsc.cingular.com
MMS proxy: 66.209.11.33
MMS port: 80
MCC: 310
MNC: 410
Authentication type: PAP
APN Type: default,supl,mms,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
Enable/disable APN (Box checked) Apn enabled
Bearer: Unspecified
I think you might have missed this step:
Once you do the edit I have listed above, reboot the phone. Add in a temp fake second APN, then get back to the main APN screen. Once you are there hit the menu button and select reset to default. Magically the new edit you did to the apns-conf.xml file will show with your Straight Talk edits. After that everything will work!
If you fixed up the apns-conf.xml file once you do the above step it will edit the default apn listed. You still will not be able to actively change it inside the android gui, however since you edited it at the file level you should be fine.
Are these the steps if you have a rooted S4? or just a regular s4?
I have the new apn setting for Samsung galaxy s4 for straight talk using a at&t phone for lte
NAME = STRAIGHT TALK
MMSC = HTTP://MMS-TF.NET
MMS PROXY = MMS3.TRACFONE.COM
PORT = 80
after you enter the new apn make sure to save the apn and delete the old apn and shut off the phone and restart and everything will work including mms and internet
what sims do you have do you have the new lte sims or the older one
do not put anything for the port after the apn I have the galaxy s4 and the new sims for lte and mine works great
I have a Samsung Galaxy S4 I9500 unlocked, bought from newegg unlocked. I used it for a month in Spain with a phone only micro sim from movistar, no problems, just used wifi for data. Now I am back in USA, bought straight talk micro sim (appears to be t mobile from default APN) and cannot get data/internet or MMS to work. Spent an hour on phone with straight talk tech support, they gave me two sets of APN data to try (see below). Neither worked, so they say the phone is bad.
Tried changing some parameters with what has worked for others in this thread, and big problem right now is that any time I change the MNC to 410 from 260, when I go to save the set of APN data it gets deleted. Any suggestions? Samsung says its a straight talk problem not a phone problem, including not properly saving APN data.
set 1
APN: wap.tracfone
Proxy: 216.155.165.40
Port: 8080
User name: not set
Password: not set
Server: not set
MMSC: http://mmsc.tracfone.com
MMS proxy: 216.155.165.40
MMS port: 8080
MCC:310
MNC: 260
Authentication type: none
APN type: not set
set 2
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User name: not set
Password: not set
Server: not set
MMS proxy: mms2.tracfone.com
MMS port: 80
MCC:310
MNC: 260
APN type: not set
thanks for any help - Mark
set 2
APN: att.mvno
Port: 80
User name: not set
Password: not set
Server: not set
MMS port: 80
MCC:310
MNC: 260
APN type: not set
Try changing MNC to 410
I've been dicking around with this phone for over an hour now, thanks for all of these suggestions y'all! Finally online and able to send MMS with an unlocked S4 octo-core on ST, this finally works for me - the "NAME" field appears to be just for reference, too. Just try using those settings and change your MNC - hopefully yours will work too.
pamatika
