Scrolling seem weird?
Mine only happens when I use the my magazine feature when scrolling to the left.
****. This will be a deal breaker if so and is exactly what kept me off of Android previously.
I'm going to check it out at the store. Not sure what I will be getting if it ends up being bad.
Well I went out to buy the S6 and came back with an iPhone 6.
The issue with scrolling seems to stem from the touch screen being too sensitive so you need to pull further than you think while still moving your finger at the right speed.
I didn't see the issue on the One M9.
Anyways, it was going to bother me too much so went with the iPhone. Too bad,I was really looking forward to the S6.
Who cares if you have an iPhone? I have a 6 to go along with my S6.
Well yes there is an issue with scrolling on the S6, at least with my one and it seems with others. However, despite the few drawbacks of the S6, it is a really good phone overall. Not sure how much time you spent with it to decided it wasn't for you, but it does have other nice features about it.
Regardless, I hope you enjoy your purchase. Nothing wrong with an iPhone 6. It's a great device.
Sent from my Nexus 9 using Tapatalk
Wonder if Samsung will fix the odd scrolling in an update?
I would hope Samsung could fix this with an OS update, if they thought it was a problem. I'm also surprised none of the reviews I've read online mentions this issue. Luckily, changing the animation transitions settings seems to have fixed it for me.
Turning all animations off fixed it for me too just now. Awesome but I will miss the nice animations lol
Never understood the draw to an Jony Ivy phone. I have every Apple product made in my house and I love them, their phones always seemed too sophomoric and cultish.
Your Jony Ivy phone isn't perfect either, its needed some updates too. In time, I think Samsung will iron out all the kinks.
I've bought a good bit of tech in the hopes of them getting ironed out later and it has rarely worked out too well for me.
Anyways I really did want the s6. I am pained to add Lightning charging (slowww) instead of Fat charging Micro USB and Wireless Qi which I already had on everything else.
Other than that I think I will be pretty satisfied. It just sucks that the scrolling had to be that way. That stuff really bothers me and the reason I considered the S6 was because everyone said it was butter.
I can't speak for others, but I'm not having any scrolling issues. Not with the 3 browsers that I've tried. Not on any app as well.
I'm on AT&T if that helps. I know Hero isn't even in the US, but if anyone has this issue, please state what carrier you are on or what country you live in.
In fact, I can't find any bug or issues so far and I'm going ballistic trying to find any.
I'm not having any scrolling issues on Sprint gs6 edge
Posted on my Galaxy S6 Edge🔪(S is for Super) via the Android Central App
I first noticed the scrolling issue with the AC Forums app, when I'm scrolling through the postings. Depending on how I flick up on the screen to scroll, it will stopping suddenly (more so than any other smartphone or tablet I've used). Of course, I could get use to it eventually or train my finger to flick harder, etc. But, luckily changing the animation transitions settings fixed the issue for me.
I have an AT&T s6 (and ip6) but the scrolling with animations off is still there. Twitter scrolling is really bad.
Turning off animations and disabling the Flipboard thing to the left of the home screen helped but it's still not what it should be.
tahirmehmoodkhokhar786
