[Solved] Nexus 4 won't turn on or charge
Re: Solved - Nexus 4 Won't Turn On or Charge
THANKS THANKS THANKS,
life savior, searched the whole internet, no fix, finally tried this and im back, thanks again
Thanks for sharing, this worked for me too. Got the red LED flashing, I disconnected the charger and connected it again and it started charging normally.
Thanks so much.. this worked for my N4
My Nexus 4 wouldn't turn on or charge today, but I was able to figure out the problem after doing a few quick Google searches. I'm posting this information in case someone else has a similar problem.
Apparently my Nexus 4 was running low on power, so it went into a deep hibernation mode. I thought I could simply charge it, but instead of seeing a charging icon, my screen was completely blank and unresponsive. Pressing the power button didn't do anything, and I was worried that I bricked my phone somehow. I then performed the following actions:
1. Remove the case off the Nexus 4.
2. Hold down the power and volume down buttons.
3. Insert the USB charging cable into the Nexus 4 while continuing to hold down the power and volume down buttons.
After a few seconds, the screen displayed a green android and a menu of options. Using the volume up and down buttons, I selected the option to Start, then I pressed the power button to confirm my selection. My Nexus 4 then displayed my home screen. I was then able to charge it normally.
By the way, I originally tried this procedure with the case on my Nexus 4, but somehow the case was preventing the buttons from waking up my phone. Removing the case made it easier to press and hold down the buttons to wake up my Nexus 4.
My won't charging is completely over and by the time I reach home, my Nexus died. I tried charging it for the whole night and thought my OS got corrupted and cursed my self for the stupid thing. Today I thought of taking it to LG service center and gave a last try searching it on Google and found your solution. I worked like a charm. Thank you,Thank you,Thank you sooooo much Scott.
Regards,
Swetha,
All Reviews
Wow, Thank you!!! It worked. I had been worrying all day. So glad you shared
Thank you for posting this, I think you saved my Nexus 4. I'll write about my experience because my visual cues were a bit different and it might help some others.
I used my phone right up until it shut off (never again!). As usual, I plugged it into a laptop USB port to charge. 2-3 hours later I picked up the phone and tried to turn it on only to see a large white battery icon (2/3 of the screen) on a black background. I unplugged it and plugged it back in again, and got a lightning bolt to show in the middle of the battery icon, but then it went back to a white battery icon with no lightning bolt, which seems to indicate that it was not charging. I got out the wall plug and had exactly the same experience so I came online and found this post (thank you again!)
However, when I held down the volume down and power buttons, I got only a blinking red LED. There was no android start menu, and when I let go it returned to the large white battery with a lightning bolt, and then without the lightning bolt as before. I believe the red blinking LED indicated the battery was charging, so then I repeated the process (unplugging, hold down the volume down and power and plugging it back in, got the red LED) but this time held down the volume down and power buttons while I read all four pages in this post (about 9-10 minutes). My finger then slipped and the dreaded blank battery icon appeared. On my third attempt, I did briefly get an android start screen, but it blinked off almost immediately (before I could read anything) an went back to a blinking red light. I held it for another ~5 minutes and then did the steps a fourth time and got an android start screen with a green arrow pointing at the power button, which I pressed. The phone booted up and now seems to be behaving as normal when I plug it in (my locked screen shows, tiny charging battery icon in the top right corner, blue blinking LED at the bottom).
So, in addition to the excellent advice by Scott7217, I'll add the following:
1) If you don't get the android start screen upon performing the steps, but do get a blinking red LED, don't yet panic.
2) If you get the blinking red LED again, try holding down the buttons as long as you can (presumably to get enough charge into the phone to allow other functions to work). This may mean 20 minutes holding down the buttons.
3) Large white battery icons with no lightning bolt seem to mean the phone has no battery power AND is NOT charging. Further, if you get a large white battery icon WITH a charging lightning bolt in it, check it again in 30 seconds, because it continually reverted (for me) back to a large white battery icon with no lightning bolt.
4) If you can get enough charge into the battery (It took several tries and maybe 15-20 mins of holding the buttons down for me with the red LED blinking), then the phone will eventually have enough power to get to the android booting screen, at which point you can push the Power button again and the phone will likely work as normal again.
Good luck, and thanks for all the advice everyone shared here!
Last year about this time, my sister's nexus 4 broke, she dropped it and shattered the screen and it won't take any input from the screen. It was left there until I decided to fix it with a digitizer I ordered from ebay. So after a year, i changed the digitizer and followed the instructions to the letter. Everything seemed alright, however, it won't power on. Whenever I plug in the power, it would show a red light and quick disappear.
Until I came to this thread, I held down vol down + power keys and then plugged in the power, I would be taken to the fastboot screen. However, if i let go then, it would show white Google logo and turn off. I kept hold it, sometimes it would show a blinking red light while I kept on holding those two buttons, while other times it would take me to fastboot screen, however this time it won't restart. I used the vol controls to go to 'start' option, but every time i do so, it would show the white google logo and turn off. If I selected recovering, it would do the same. I am running out of options, is it battery? Remember it was unused for like a year, and I charged all night even though it showed no led indicator.
I need help
My guess is that your battery is having difficulty retaining a charge. If you have your Nexus 4 plugged in and you don't see an LED turn on or a flashing white battery icon in the middle of your screen, then nothing is really happening. So you could have it plugged in for an entire week, but the battery will remain at 0% charge.
I would try repeating the procedure multiple times in one sitting. Keep trying to get that white Google logo to show up on your screen. If the phone shuts off, try it again and again. I remember going through this procedure at least 5 times in a row, but my battery was only dead for about a day. Yours has been dead for a year, and that probably makes a difference.
It's also possible that your battery is defective. You may need to get a replacement battery from eBay. I don't know how hard it is to replace the battery, but at least you have some experience disassembling your Nexus 4 since you replaced the digitizer.
THANK YOU SO MUCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! You saved me and my Xmas and holiday travels.
Phone just discharged, went off, when tried to put it charging red light started blinking.
Tried all the possible, immaginable button combos, tried charging it with wall charger and from a pc. left it on the powercord, and blinking, for 24h. nothing.
Final fix for Nexus 4 red light of death - xda-developers
as suggested here i opened the phone.
I managed to control my battery power output and its 3,9v. So i placed it charging, with no results.
Than i see that if i disconnect the battery, and i try to charge the phone (with no battery), for an instant the phone turns on. So i flip out battery put on charger, in a split second put battery on and phone is responsive. so the charging icon pops out and apparently it startes charging. Screen goes dark, no red blinking, powercord on, i leave it like that for 8h, and try to turn it on again. bang red light as nothing happend. currently im trying to give it more time like 24h charge, still i suspect that even though it shows charging icon it does not charge.
my other options are trying with a wireless charger, some say it workes.
and oredering a new battery.
The minute i fix this phone im selling it fast, never again LG.
My phone just did this same thing...wouldn't start up no matter what I did....I know I had shutdown the phone and that it was charged to 100% before I did that so it wasn't me running the battery down. I did think that maybe it somehow got started while in my briefcase and then ran the battery down.
I followed the instructions at the beginning of this thread and only got the solid red LED. I then unplugged the USB cable, held the buttons down for 15 seconds and then plugged in the USB cable and I got the green robot, pressed the power button for Start and now all is good....when it came up I confirmed that the battery was at 100% so I'm a bit concerned that this phone did this...I'm running stock Android...
I have tried this a few times and sometimes it will turn on and then turn right off. Finally it just started having a solid red dot. Randomly turned on again and off again. Then it will randomly flash red but then go solid red. Is there anything I can do? I had a drink spill on my lap while my phone was in my pocket tonight but it barely got any on it. Will buying a new battery help?
Thank you so much for the help. I was so worried about the phone not charging.
My phone gets to boot menu and then crashes to the white Google logo. When charging red light blinks, but otherwise it shows nothing.
Would replacing the battery help?
Hi !
Thanks a lot for your solution. It works, but there is a 2nd problem that I don't know if you have come across.
After bringing it back to 'charging', it's been charging for 40min now, but it is still only 1% charged! It was turned off when it was first retrieved and charging, then I turned it on for viewing how much it has charged. It normally takes 20-30min to be 20% charged, fairly efficient. But now, it is still 1% charged, which simply means not charging. I can imagine it will die straight the way once I unplugged it.
Have you / any of you experience this? Does it mean the battery is dead?
tinni99
