Sprint S3: Wicked Sensations 5.0
Re: Wicked Sensations 4.0
Ok everyone, Dazed has the twisted pink them along with other pink mods up. They can be found in the kuban updater.
Sent from my GS3 sporting Wicked Sensations...
Total noob questions - sorry. Do I need to root for this? I read the instructions but didn't see any mention of this.
Thanks.
Re: Wicked Sensations 4.1
Dazed's Anakonda theme is live in the updater. Its a really awesome looking orange and green theme.
sent from my GS3 running Wicked
I installed this using the instructions and everything seems great so far except for copy/paste. If I long press to paste in any app I don't get option to paste.
Any ideas how to resolve?
Sent from my SPH-L710 using Tapatalk 2
This is an awesome theme and I highly recommend it. Be sure to update both Google Now (search) and Dropbox from the Play Store, as well as sprint voicemail through the app's settings if they are not already on the most current version before you flash.
Hi, after updating all apps and rebooting a few times (for some awesome mod installs) copy/paste is ok.
Thanks.
Thanks.
Ok good deal.
Folks, I gonna need your help. This week I start managing a 9/10 yr old all star team. So please feel free to help keep this thread up to date. I won't be able to keep tabs as well for a bit since all my time not at work is gonna be on the baseball field. Thanks.
Very cool I hope your boys go far. I will add any pertinent info in the meantime. Good luck!
Sent from my Nexus 10 using AC Forums mobile app
A couple questions:
I'm still on 4.0 right now and for some reason every time I go into my task manager I see that Google Play Music is active and consuming around 15mb RAM even though it's not technically running. How do I prevent this from happening or is it supposed to? This didn't happen before.
With the 4.1 will I be able to use Google Talk still through Kuban because I don't like Hangouts at all. I use it primarily at work and it's a pain in the ***.
A couple questions:
I've seen where other people have had the same complaint with Google Play Music. Not sure why its doing that. If need be you can go into application manager in the settings and force stop the app. If it is that bad and you don't need it, then you could freeze it with TB.
Yes, you can still get Google Talk through the Kuban Updater.
Not so much a problem with wicked 4.1 but with the new anakonda theme.
Since I flashed it my reception has been horrible in places where it used to be just fine. I didn't do a full wipe since I flashed over wicked 4.0. Is there a new modem or anything I'm missing?
Sent from my SPH-L710 using AC Forums mobile app
That picture shows that you are on WS 4.0, not 4.1. Did you download the Anakonda 4.0 theme, put it on your SD card and flash over WS 4.0? If so I would update to the newest version of WS to see if that does anything to help you out. Also, In the updater there are several different modems that you can try out. See if one works out better for you. Be sure to update your profile and prl if you update. Another thing you can try is ##72786# in the dialer.
godef
