citiz
One last question and I'll just wait for the update zip. Why does Odin see my phone in debugging mode when I plug it in? That's whats going on.
hi, i have 2 quick questions about the PIT files... i have 2 files saved s1_odin_20100512.pit and victory_8G_100528.pit which one is supposed to be the latest and which one goes with OS version (DI07, DI18, DK28)? thanx
See first post, "Helpful Links"Question: What state does my Eic4g need to be in to upgrade to EB13 when it comes out? Do I need to flash back to the stock rom, unroot the phone and remove clockworkMod in order to download the OTA update?
Again see the first post, it answers your questions.If I wait for you guys to release a package with the update, do I NEED to install it through the factory recovery mode or can I do it through clockwork recovery? Also, if I do it via the package you guys release, do I need to remove the root so it doesnt conflict with EB13? Will I have to use Odin at all if I use the package you guys release?
Yes we enjoy giving back to you and the place that has given so much to us.Also, do you guys just release all these updates because you enjoy doing so for the community?
Well then I'm screwed. I didn't save all my removed apps. Some, but not all, and I've tried installing update.zips manually and got errors each and every time. I used to mess with my BlackBerry all the time, bricking it then fixing it with no problems. I try to follow instructions for the same thing on Android and I get confused beyond belief. I'm not stupid, but not a single set of instructions to install an Android OS has made sense to me.
I'll deal with 2.1 until I get a new phone. Screwit.
I'd have to agree with that. I think its going to b exactly the same but work smoother. And by work smoothr I mean in comparison as to how 2.1 worked after the latest service update. Wow, how long has that been. Hmm.
YesI had to use Odin to flash my bricked Epic back to stock Eclair. Will I still get the OTA to Froyo?
Your choice. You can Odin back to stock and get the OTA or use the manual update.zip method when its available. Or you can wait it out and see what is created in the form of flashable upgrades using CWM or Odin but that could take a few days and there is no promise that you will be able to go from your current state to Froyo EB13 without still having to Odin back to Eclair.Asking for opinions here. I'm currently on TER 1.5 EXT 4. However due to flashing some different themes over top of one another i'm beginning to have some force close issues, and just general bugs with my current setup, however I love having root and being able to customize pretty much anything! My question is, should I revert back to 2.1 now and wait for the OTA EB13 update and start fresh, or wait for WONDERFUL devs at xda to set things straight with Froyo? Suggestions?
Yes
Ahh great thanks for the advice! A few days after the update the devs should have a rooted EB13 with ext 4. Maybe a one click root with cwm3 for EB13? I'll probably just odin back to get the update via the ota or manual .zip file.
