Ultra Keyboard 6.5.1
Re: Ultra Keyboard 6.2.3
6.2.6:
New:
? Modified v7 theme.
? Added "On Indicator" to themes.
Fixed:
? Various memory leaks.
? Got force-close when starting keyboard from landscape.
? Typing quickly would sometimes clobber previous text.
? A race condition while tracing sometimes caused A) a crash, or B) an incorrect trail.
? Deleting previous words wouldn't always clear the suggestion bar.
? Click to copy device ID in general settings caused force close for certain devices.
? Notification icon wasn't working correctly.
6.2.7:
Added:
? Full-screen editor scroll arrows.
Changed:
? Suggestions are no longer shown for words starting with digits by default (can be changed in settings).
Fixed:
? After switching from and back to Ultra, settings changes wouldn't update.
? Tool bar select button didn't work in full screen mode.
? Full-screen editor hint text wasn't properly aligned when zoomed.
Re: Ultra Keyboard 6.3
Updated to 6.3.
General:
? Fixed various crashes.
? Fixed status icon size issues.
Themes:
? Updated the v7 theme (thicker keys; color tweaks; Ubuntu font).
? Added a dark variation on the v7 theme (now the default).
Suggestions:
? Added ability to change the fonts.
? Fixed problems with word layout/positioning.
? Fixed vertical scrolling not working.
Keyboard:
? Improved camera overlay.
Keys:
? Aligned secondary characters to the right.
? Fixed text positioning issues.
? Optimized graphics routines.
Re: Ultra Keyboard 6.3.1
Updated to 6.3.1.
General:
? Added new minimal icons (can be set in themes under "General" and "Tool Bar").
? Fixed various crash issues.
Themes:
? Added "Suggestions -> Shadow".
? Added "Tool Bar -> Shadow".
? Added "Keys -> Secondary Alignment".
? Now offers to make a new/modified theme active after saving.
? Made default invalid suggestion color slightly darker.
Suggestions:
? Prevented bar from being dragged when trying to select a word.
? Fixed bar positioning issues.
? Fixed bar theme colors being ignored.
Keyboard:
? Fixed modifier key shadow.
Gestures:
? Added targeted "View", "Layout", and "Dictionary" actions.
Re: Ultra Keyboard 6.3.2
Updated to 6.3.2.
Fixed Crashes:
? Adding a custom word or replacement via the tool bar.
? Going up one directory while at the root directory in the Backup/Reset file chooser.
? Accessing Typing settings on devices older than 2.0/Eclair.
? Loading fonts in the theme chooser on devices older than 2.0/Eclair.
General:
? Now using the Holo theme for devices using 3.0/Honeycomb, 4.0/ICS, or newer.
? Tweaked the UI in various areas (and cleaned up any inconsistencies).
Re: Ultra Keyboard 6.4
Updated to 6.4.
Fixed Crashes:
? When speech to text support is not found.
General:
? Improved dialog windows.
? Fixed hidden (hard to see) result text for translations and speech to text.
? Cleaned up UI inconsistencies.
? Fixed notification icon for Cupcake/Donut.
Themes:
? Improved UI theme support (settings->Themes->UI).
? Black Theme by default on Gingerbread or older; Holo Black for newer devices.
Suggestions:
? Improved suggestion bar performance.
Updated to 6.4.1.
General:
? Fixed issue where you couldn't type in certain text fields (such as when adding a custom word).
Keyboard:
? Quicker loading across orientation changes.
Themes:
? Fixed incorrect color chooser layout when changing orientation.
? Fixed color palette positioning issues.
Tool Bar:
? Fixed scrolling and performance issues.
? Fixed incorrect item position after changing the theme.
Typing:
? Better handling for sudden motion "jumps" on certain touch screens (increased accuracy!).
? Space bar now registers on release, not press.
? Added Gestures as a typing protection component.
Re: Ultra Keyboard 6.4.2
Updated to 6.4.3.
Fixes:
? Missing text cursor in full-screen editor.
? Speech-to-text auto-space behavior (and added a setting to disable it).
? Soft keyboard popping up when using a physical keyboard.
Updated to 6.4.5.
? Fixed capitalization issues.
? Hitting backspace to revert a correction, then typing space again, now inserts the word without correcting it.
? Changing orientation should now be slightly faster.
Re: Ultra Keyboard 6.4.5
Updated to 6.4.6.
? Fixed landscape arrow key issues.
? Added ability to use Google Voice Input for speech-to-text (Android 4.0 and newer).
? Other minor fixes.
Re: Ultra Keyboard 6.4.6
Needs text prediction similar to SwiftKey... Then it will be great.
Sent from my SGS3!
Updated to 6.5.
Keyboard:
? Added custom Key Previews theme support.
? Added new Android 3.0-style emote icons (and theme support).
? Fixed back button behavior when showing all suggestions.
? Fixed back button closing the keyboard entirely instead of only the suggestions bar.
? Improved gesture sensitivity.
Typing:
? Enabled key previews and sound, disabled vibration by default.
? Fixed crash with compact key previews in tap mode.
? Fixed capitalization issue when using multitouch.
Typing Protection:
? Added "Typing Protection/Enable" setting.
? Disabled by default.
Suggestions:
? Added "Allowed Text Fields" setting.
? Added ability to enable suggestions for text fields that request them to be disabled.
Tracing:
? Fixed capitalization issue.
? Added fade out animation.
Sounds:
? Added theme sound set options.
? Set the sound source to system media by default.
Tool Bar/Keyboard Settings:
? Added "Typing Protection".
? Added "Feedback/Key Previews".
Other:
? Improved clipboard performance for Android 3.0+ (using a listener instead of polling).
? Fixed "Google Voice Typing" speech support for 4.1 (Jelly Bean).
? Fixed laggy scrolling on settings dialog windows.
? Improved performance and bug fixes.
Updated to 6.5.1.
? Fixed suggestions not updating on Android 3.0+ devices when the tool bar was hidden.
? Fixed menu button show/hide tool bar feature (which was broken in 6.5).
Actually it's REALLY missing text prediction like SwiftKey 3. Please add it to take Ultra Keyboard to the next level!
Sent from my SGS3!
Updated to 6.6.
? Fixed major crash on Android 4.2 (Jelly Bean+).
? Improved height adjustment feature.
? Increased space bar width on non-compact layouts.
? Added a gap between the main and arrow keys in landscape.
? Spaced out the phone view keys.
Cheezy313Bby
