Using Hangouts for SMS/Texts/MMS is really going to take some getting used to
Hangouts needs quick reply and I wouldn't bother touching any 3rd party sms apps.
Still don't understand why they didn't add that.
This would be amazing! If they had a quick reply pop-up used for only SMS/MMS that lights the screen up when an SMS is received.
Hmmm, I didn't receive an SMS message, should be through Hangouts, not ?
Strange thing is that I have my Jolla/Sailfish phone with dual SIM but only one can work (so the Jolla is just on WiFi).
I was send an SMS (important one), but it came only to the Jolla and not to my N5 that is the only phone with tel connection (4G).
Do I need to install an SMS app ?
Whatsuppp ?
Whatsuppp ?
Try Textra. It works great for many of us. Good luck.
I agree. 8SMS is the best I've found. It's simple and just works. Designed for Kit Kat. What I like about it is the instant reply. It just works seamlessly. Good app. I found to be the best for me "hands down"!!
that's quite the man-purse. do you really need to carry around all of those cards? ever consider going minimalist?
lol.. that.. IS minimalist!
that zipper part?
that sucker holds loose change (from Coach), i've never seen a man's wallet tthat hold loose change, that in itself frees my pockets from the jingling..
& usually most of my jeans & slacks have deep back pockets, & only the tip of the wallet pertrudes..
RangelS25
