Installation went smoothly without any problems.
It took a while to find in settings the "Doze" feature in order to set it to be ignored for certain apps that I always want to run in the background. I found it under "Ignore optimizations" (it isn't called Doze) after pressing on Battery Usage. This feature potentially can lessen battery depletion during longer stretches when your phone is stationary and not being used. It shuts down all unnecessary background programs that waste your battery, , but allows you to override the feature for apps you check off that you want always to run.. I hope this feature works as well with my G4 as it did with my Nexus 7. This feature alone was worth the MM upgrade for my Nexus 7, making a major improvement in battery life during down times.
So sense its not called Doze, is the Ignore Optimizations working the same as Doze??? Im yet the phone run down.
Installed it a bit ago and I've noticed that the 4GLTE is lit back up when on WiFi again and the up/down arrows light up every now and again.
Liked it better when it was off when WiFi was on... now I'm not sure if it's still trying to use data while on WiFi.
Not sure why it does this but my Samsung Galaxy Note 5 does this as well. It isn't using any Data, which is good but it is confusing. Can't figure out how to eliminate that either. Maybe it's a Vzw thing.
Anyone know when it's coming out for samsung?
Sounds like you have data and wifi on at the same time.Only data shows 4G LTE...did you check it in settings and make sure its off .
Did the update on my LG G3 today. Completely wiped my SD card so now I no longer have my music stored locally on my phone...what a pain in the rear!!
So you are saying that the update to MM on your G3 just wiped your external SD card? Everything went fine with the update and it just wiped your SD card for no reason?
I feel like there is some missing information here. Crazy things happen but this seems way out there.
My wife's Note 3 had an update come through a while back that did the same thing. It completely reset the phone and wiped the SD card. Once up and running, it operated fine. So now I always take the SD card out before performing an update or FDR. It's not supposed to wipe the SD card, but it can happen.
