Verizon Motorola Droid Turbo VoLTE or Simultaneous Voice and Data
Re: VZW Cutting It Close With Promised VOLTE
Come on guys, you know VZW just rolled this update to prove me wrong in starting this thread. Give me credit where credit is due:)
They made their unofficial commitment deadline. Mark this day on your calendar.
Like I said, premature and undo hysteria over baseless assumptions. Wish i had that much time on my hands.
I gotta be honest here. I could care less about this feature. I would like to see lollipop before this. The area I travel has a few spots that switch data to 3g because 4g signal is weak. I probably wont even activate it. It is nice they are starting to roll it out though. I know they are changing some 3g signals over to 4g so maybe the signal will get better for the are I travel through.
I don't care, but I just don't see using data and voice at the same time. I never have before and I don't see doing so in the future.
A few examples...
Talking on the phone while using navigation
Being on the phone and saying "here, I'll send you this picture."
While on the phone, "Hang on, let me look that up."
I've frequently wanted to send someone a pic while talking to them.
A few examples...
Yah. just taking a call while navigation is running. Never knew how often I did that until the message kept popping up on my Turbo.
Posted via the Turbo
List Things You've Noticed from VoLTE Update
Let's list the things that the HD Voice/VoLTE update has changed.
I received the update this morning. In other threads people have noticed:
1. Faster WiFi
2. No more data leakage/usage while on WiFi
3. Reduced battery use while phone is "idling"
4. Ability to remove Google search bar from stock launcher
I've taken a couple of phone calls (strange use for a cell phone, I know) and noticed:
1. Much, much louder volume in the earpiece and speaker phone. I mean I needed to turn the volume down to about 50%, where previously I needed to have it almost maxed out.
2. New look and new controls on the "phone active" screen. The red bar icon for hanging up the phone no longer stretches all the way across the screen, near the bottom of the screen. Instead it occupies the center one-third of the screen near the bottom, flanked by a touch area for "camera on" and "one-way camera". Bottom row of this screen is the familar "Dialpad", "Speaker", "Mute", and "Add Call" icons.
Kind of like this:
If you've noticed anything else from the updates please chime in and list them in this thread.
Re: Huge gap in VoLTE functionality, or am I missing something? Want a turbo but....
FYI this feature is now rolling out.
Re: List Things You've Noticed from VoLTE Update
My notifications seem louder also. Noticed it when I got my first text after the update.
faster Bluetooth connection.
will anything else fit where the google bar is?
I have the update and still can't remove the Google search bar from the stock launcher.
'14 X user hear so I'm still waiting for this. However, have any of you had dropped calls (or excessive dropped calls)? My wife's G3 just got it too but I have not enabled it yet.
Call volume better, battery life jumped, cell signal strength increase 1 bar, HD voice available in settings if turned on in my verizon app, lte cdma umts setting available
Not sure I like HD voice over better/louder regular sound in call
WIFI way faster
Bluetooth improvement may be helping ware watch (GWr) battery life
EDIT: Nevermind, it was because I had my phone plugged in to charge. It went back to solid color after I unplugged it.
The first thing I noticed is that the battery life indicator on the command center widget has a more "textured" look to it, whereas before it was just a flat solid color. Just something cosmetic, haven't used the phone much yet to find other functional changes.
For those with the flip case: media controls in the window now!
If you reboot when in silent or vibrate-only mode, the startup sounds will also be silent - except for a quick vibration.
Great to have a dedicated thread for this.
Battery shows 100% when fully charged instead of 99
Long press on home screen and choose "Settings" to disable google search bar ... thumbs up!!
Not being able to actually USE THE SPACE gained for widgets .... thumbs down!!
byronsss
