Verizon XOOM gets ICS next week!
:'( Note from Motorola regarding the Xoom update:
"We're testing final software. A group of some thousands of Xoom owners will recieve the upgrade. But only a portion of that group is made up of owners like you, from the Motorola Feedback Network. It's your feed back that we rely on in evaluating if our software is ready."
So it is just a soak test. :'( :'( :'(
via droid-life
It's on droid-life.com too. Well I guess that means in a week or two it'll be pushed out to the little people.
Actually, it's like other soak tests that have been done. It will be pushed out to some normal, regular users in addition to those who specifically signed up for the soak test (and are therefore under NDA). Those who signed up and are accepted will be able to post on the MFN. The normal users who get it pushed to them will not. Therefore, SOME lucky users out there will get it pushed with no NDA starting today.
The signed update zip from google has been posted. I think she's live now, regardless of whether it was just a soak test or not. :)
The update is available on Droid life as a zip file. Fyi
Installing on my tablet as we speak. Just came thru:D according to my email it is a soak test.
The manual update will only work for build HLK75H, which is not mine. Guess I gotta wait for the soak test push.
cool, screen shots work! press power button and volume down at same time and <beep> screenshot saved to gallery.
there's no folders on the home screen though...I thought ics had folders....
I'm done checking for updates every 20 min. Hopefully it'll be waiting for me in the morning
OTG cable required. Couldn't wait any longer and took the plunge: If you follow the instructions carefully, it'll work fine. ICS is great!
Sent from my Xoom using Tapatalk 2
rosannejoy555
