"Whole" Punch Makes a Notch Seem Good
Re: Whole Punch Makes a Notch Seem Good
And there lies the solution. Buy a Note 9 or keep your Note 9. Samsung doesn't owe anyone the same form factor from series to series.
Maybe hole punch haters with be happy with the Note. Problem solved.
Or, don't appease a bunch of vain selfy obsessed people with holes. ;) I'm only half way kidding ;)
And the hole. Then again, the hole haters could be offset by a bunch of vain selfy addicts.
It's only better in terms of additional hardware that was removed
That's a valid point. I understand that many feel the hole looks better than the notch. I even tend to agree with that (although I would also be okay with neither - and back to bezels), but the hole seems to come at the expense of LED and Iris scan. Is it worth it? If you don't use them anyway, I guess it's a good trade off. Otherwise, not so much...
I find it hard to believe that they couldn't find a way to integrate them into the whole punch.
I could tolerate that, even with the inconvenience of the new fps.
You find a notch which is 20x the size of the holes we're talking about to be less noticeable or intrusive than a small hole(s) on the top right of the screen?
That's a real head scratcher.
The hole punch doesn't fit with the symmetry of the design. Its just a hole off to the side of the screen. With the notch you get symmetry, from each edge you have same distance to the notch itself. If the notch was to one side I would absolutely hate it but its perfectly centered unlike a hole on the right side of the screen.
Edit: Spelling is fun.
the notch is definitely NOT better than the tiny hole
That's fine if you feel that way, but it's really a matter of preference and it depends on how the notch is laid out with features. I prefer something on the edge. There is room for improvement on the notches. As an example on the pixel they could eliminate the front fairing speakers that would reduce the size of a notch and the bezel at the bottom. Of course some people can't live without front firing speakers.
I like that Samsung put it to the right side. Symmetry doesn't work with a hole punch. A hole in the middle of your screen would be even more noticeable. The notch really doesn't bother me either (except that evil looking thing on the Pixel 3xl). But a notch on Samsung's Infinity display would be a crime.
I too prefer the hole to be in the corner. For games and video in landscape, I'm so used to logo's, etc, being in corners that my brain hardly even notices them anymore Movies almost never use corners for anything important, but you'll sometimes have characters, places, or objects that exist on the edge.
Is a notch preferable here? I'd prefer to turn my phone so there is a hole punch in the bottom right.
Then you get a giant black bar on the top of the screen. Which takes away from the screen size.
That's the whole point of a topic about the hole. Even left the misspell as tribute. The 10+ has a hole, curved edges, and curved corners. Trifecta of display evil! ;) :)
At least my beloved N9 only has curved edges.
I think the hole is better looking on the homescreen but not good for YouTube video but the notch is better when watching video because the video will stop under the notch (on my OP6)
If you compare to iPhone the hole is much better than the notch.
You're right....the hole is much better but that's from your perspective. Someone with the opposite view is also right. This applies to any feature debate.
No we're talking about the market as a whole. Normal people aren't going to give a darn about the hole.
Do you know how big the hole punch would have to be for those components?
Master zx
