Why a 16MP camera is better than 12MP
Well, this post is going to be a long one. So sit back, relax and grab a cuppa because you're about to learn something you probably haven't seen before.
I can understand why one would think a camera with a higher megapixel count would do better than a lower megapixel count. That's because megapixels denote a camera's resolution, with a megapixel being approximately 1 million pixels. It's not hard to know that in theory, a camera with a resolution of 21 million pixels will resolve more detail than a camera with 12 million pixels. It's part of the reason why people seem to think 21MP is undoubtedly better than 12MP.
However, this is a basic fundamental judgement error people often make. Cameras are not always about one parameter (in this case, resolution or megapixel count). Instead, they're more about multiple factors such as;
  • Lens quality: The quality of the lens denotes how sharp an image could be, especially around corners, and good quality lenses will have less artifacts such as fringing and chromatic aberrations.
  • Sensor size: The actual size of the camera's image sensor.
  • Pixel size: The actual size of each individual photodiode. This relates to MP count and sensor size
  • DSP: Known as a digital signal processor, this is the stuff that makes the automatic wizardry in your camera work.
  • Processing: How a camera processes a RAW file from the sensor into a compressed JPG matters since techniques differ from manufacturer to manufacturer.
  • Aperture f-stop: Denotes how big an aperture is in relation to a camera's focal length. Do note that an aperture of f/1.8 is not universally similar since it differs in relation to the focal length of a camera.
  • Stabilization: Helps stabilize a shot in order to reduce blurriness or increase exposure times in non-ideal lighting environments. Can either be optical or digital.
These aren't everything that makes a camera, but they're among the most critical.
Now, back to this.
Let's take the V30's 16MP main camera and dissect it for a bit.
The V30's main camera sensor is an Exmor IMX351, a backside-illuminated CMOS image sensor with an effective resolution of approximately 16MP on a 4:3 aspect ratio. On paper, that sounds fine, but here's the kicker. The sensor size is among the smallest on any flagship phone, at a mere 1/3.1", and as a result, the sensor size is probably the smallest, at 1 micron. For comparison, the iPhone X is around 1.22 microns, the Huawei Mate10 is 1.25 microns on its main camera, and the Pixel 2 XL, Galaxy Note8, HTC U11 and a Moto G5+ pack 1.4 micron pixels and have the largest sensors in this lot (1/2.6" vs 1/2.9" on the Huawei, 1/3" on the iPhone and 1/3.1" on the V30).
At first glance, that doesn't seem too big right? Like what does pixel and sensor size have to do? Well, quite a lot actually, moreso than megapixels.
The job of a photodiode is to capture light and resolve that light info into digital data that can be processed by the DSP into a suitable JPEG (although one can skip the JPEG processing if one wants to edit the RAW files in Lightroom). Here's where the problem lies. Smaller photodiodes are less capable of sensing light, and when they're packed so closely together, there is a tendency for them to "bounce around" or crosstalk, sometimes causing patches of weird color noise that you see in some RAW shots taken in very low light. While this problem isn't as noticeable in daylight, the smaller photodiode size also means they're more likely to be "flooded" with patches of higher exposures in contrast to lower ones. Which is why you sometimes see blowouts in highlights, mainly due to the photodiodes' limited ability to resolve detail. It also bears mentioning that because they're less capable of sensing light, the ISO would have to be jacked up as well, increasing luminance noise.
So in your particular case, I'd wager that the 16MP sensor wouldn't immediately be a clear victor, mostly because the noise-reduction has to work extra hard to curb some of the increased noise levels due to the smaller photodiodes caused by a combination of a higher resolution on a smaller sensor. The f/1.6 aperture can help but it serves more to balance out the drawbacks. If anything, the output probably won't be much different from that produced by a U11 or Note8.
Reason why most of the OEMs seem to have stuck with 12MP is because on the limited size on phone sensors, 12MP offers a good balance of detail, noise, dynamic range and luminance. It's also why companies have stopped chasing for more pixels and have instead looked to either dual-camera solutions or increasingly sophisticated post-processing techniques via computational means, with a famous example being Google's HDR+, popularized by the 2016 Pixels and recently made their way onto more phones with the help of XDA.
It's also worth noting that this isn't a problem on actual cameras due to their actual size. They pack massive sensors, so it is possible to cram in a ton of pixels without compromising on the actual shot. I'm not kidding when I say a Sony Alpha a7R Mark III is better at actual photo output than a Pixel 2 XL almost solely due to its sensor since it is bigger, has a higher resolution all while packing in significantly larger pixels. Phone cameras don't share this luxury due to limited space, so it's always a balancing act.
TL;DR version: MP doesn't matter as much now. That 16MP moon shot probably wouldn't look much different on a Pixel 2 XL.
Do you know why cropped pictures look blurry with 12MP as opposed to the 16MP? Try taking a picture of a book from far away.
Unedited cropped photo: 13MP ZTE camera VS 16MP LG V20. Tried this on a Galaxy S7 back when I had one, same result. I take landscape photos so this is important to me.
Another good example is taking a picture of someone's license plate while driving. Tried it with the 12MP, the plate was unreadable. The 16MP was able to capture it. Important if you need to report a bad driver or capture evidence.
BTW the Galaxy S7/S7 Edge/S7 Active, Note 7 camera sucks. It's only good because of the dual pixel technology, otherwise the 12MP camera was unsatisfactory, picture quality looked reduced from the previous year's model. My eyes can see the sharpness difference.
Two different cameras, probably two different sensors, definitley different software, possibly taken with different settings, etc, etc.
I don't have a Galaxy S8 to test now but I did several tests when I used to have one. Couldn't capture detail when cropping images (can't capture the whiteboard written notes on the wall).
Yeah I'm just saying if we're trying to compare different cameras, there are a lot more factors than just the MP count and also that the MP count is probably one of the least important factors.
Try it with a Pixel vs LG and your comparison won't hold water. I've compared the Pixel 2XL to the V20 and the V30 and the LG doesn't cut it crop or no crop.
It's not just about Megapixels. That's only one factor in the equation. I have a 6 megapixel camera that will beat anything you can take with your 16 megapixel camera because it has a large sensor. LG uses smaller sensors than most other brands. If you cram too many pixels into a small sensor you give up light gathering capabilities. There is a point of diminshing returns. If it was a simple matter of using more megapixels everyone would do it. LG needs to get their act together because they can't even get their software processing right. Which is why you see many happy to be using the Google ported software.
Well it's not fair if you have a telephoto attachment to it... That's like using a telescope and then using your camera phone to take the picture.
Can you take a picture of a street sign or license plate from far away? There was a crazy driver and he got away because my 12MP camera couldn't capture the license plate.. image was too blurry.
I'm more concerned about image quality when cropping and capturing distant objects. Photos can be enhanced with software.
Right, that makes sense... but MP is still not the determining factor in how well that is going to work. It's one of the least important factors.
Just curious, what camera was that taken with?
Most likey a KM 7D with a 600mm Tamron lens, however since it was a originally a 35mm film lens the crop factor using it on a digital camera makes it approximately the equivalent of a 900mm focal length lens.
The shot was taken handheld with image stabilization on.
Blurry images are most likely the result of shakey hands or too slow of a shutter speed.
Nice. Beats my 8MP Olympus E-500 on the 40-150mm kit lens. Crop factor puts it at 300mm equivalent, plus no image stabilization and not high quality glass. Currently have my eye on a Pentax K1 though.
I have a Sony Alpha mount now that allows me to use all my Minolta glass and a Sony NEX 6 E mount that is really compact with an electronic Zoom kit lens.
... with a 600mm Tamron lens
So basically a telescope with a 6MP camera, maybe try with stock lens...
Smartphone camera megapixels do count, but it doesn't mean the image quality will be great if it's higher, just more pixels in an image so when you blow it up (zoom or crop), you won't have issues with detail. Why do you think everyone is complaining about LG's front 5MP camera? Images look too grainy because low megapixels. Same with the V20 8MP wide angle.. it doesn't look bad just a little pixelated from low pixel count. Give me Sony Xperia's 19MP camera anyday over Samsung's 12MP... I can just photo edit the image later, higher means more detail.
You mean software processing.
Samsung is known to use very heavy handed noise reduction. That's why you see patches of splotchyness or blurry artifacts. It's due to that noise reduction.
Here's a shot. It was taken on the Note8 but with HDR+ instead of the stock app. It's not very pretty but you can make out some detail. This was a severe crop as well.
I have a Sony A6000 with a Sigma f1.4 prime lens. Affordable and very lightweight. Also a small Lumix GM1. Sigma makes excellent quality lenses.
Barely readable text. With 16MP, small text should be more readable when you zoom in. Note 8 camera is excellent but heavily dependant on software processing.
Uh, far away text? S7 Edge, original pic vs cropped:
Sony lettering maybe a foot tall at like 100m away.
stantn
