[WIP][KERNEL][ROM] Wildfire S Virgin Mobile USA
Ok so me and simon were talking, to where I got him to half listen. Where he isn't sure of the bricking ruu you guys flashed. So if you could give me the link I will see what it is but if I had to venture to guess you maybe got a hold of a gsm ruu. Which would explain the brick.
As far as I know there are no cdma roms yet, or at least none that are functional. The roms that are bricking your phones are gsm roms.
I did not flash a GSM RUU, I flashed the RUU for Virgin Mobile, check my post above and you will see the link.
Well i installed the custom recovery and link2sd and both are working fine and it has saved me some space so thanks for tips simonsimons.
Also is there anyway to get the wi-fi hotspot up and running on this phone. I noticed in link2sd the app for it is on there but VM and all of their glory seemed to have it locked down pretty tight. When i tried to turn it on it just stays on the processing screen for me. Just seeing if there is a work around for this.
your welcome im glad i helped
If you are rooted there is a workaround (downloading an app) download barnacle wifi teather
Great thanks for that, wifi teather is now working. My pc hooked right up to it, took me awhile to find a solution to be able to hook it up to my Touchpad though. But now that is working but i have to leave it unsecured, then delete all known networks and use a root command on my TP :'( but it will work.
Since im very new(b) to android what stock apps are ok to delete, i.e. airG, Where, Scvngr, VM Live, Twitter, etc. I am backed-up using titanium backup just not sure how the whole thing intertwines lol
Well, i found another sollution too :) Tether for root users, it has a green icon.. It acts just like an AP.
As far as the apps, you can remove: Air-g where scvngr VM live Downloads My Account thoes for sure, list all the stock apps(i allready removed mine) that look not to have HTC in the title or Framework. Ill conferm the ones more than the ones i gave you if you do that :) Also, Twitter and facebook have to stay because of HTC's sense
No i didnt sadly. I didnt see anything wrong with it. Maybe its some of the framework stuff thats wrong ? ill keep researching
First off, thank you simonsimons34 my phone is now s-off and rooted. This is my first android phone and tinkering with it is a must, especially with the terrible memory space. :p. Also Thanks to lokito15 I had the same problem with rooting as you and your posts probably saved me countless hours of searching.
Everything went pretty smooth, the two hiccups I had were getting the CID which required me restarting my pc to finally get it after installing HTC drivers. And the problem of the adb server out of date which went smoothly after killing HTC sync.
Now on to the custom recovery and link2sd. And possibly the internet trick, we will see. I will post back and let you know how that goes.
So again another thanks to simonsimons34 and lokito15. And if I ever get my finances straightened out I'll throw a few dollars your way because this was worth it. :-$
No problem, I am glad my post was able to help you out :)
Something ive noticed, about forums :) Androidforums, is noobs. Androidcentral is experienced people. XDA, just an info source, lol dont ask questions.
Hopefully that makes someone else laugh too :)
anyways, i am working on pulling the device configs to get a ROM up and going :)
Thanks simon, I have deleted a few stock apps and am so happy I dont have to look at them in apps menu anymore, Ive kept a few of them for my wife but got rid of the VM crap and some bloatware.
I will also check out that tether for root users as well. Thanks again :)
Im booting a highly custom stock rom right now guys :) this is exciting, im logcating then ill test and post it
Here we go :)
I added:
WiFi tethering (check the quick settings tab on notification bar)
DeOdexed the Rom, so it is now themeable.
zipaligned for speed
fixed some small problems with memory (got you guys a little more)
fixed the link2sd problem
Added adhoc network support
MADE THE FIRST ROM :D (with these modifications)
Here we go:
1st back up everything
2nd Wipe system, cache, dalvik cache, data
3rd install the my zip THIS WILL TAKE A LONG TIME, ITS NOT FROZEN
4th reboot the phone by clicking the reboot phone selection
5th Give it time, it wont take too long ;)
6th Enjoy the speed, features and awesomeness of my new Rom, including the native HTC wifi tethering. Something no one else has accomplished, but me
Link:
https://docs.google.com/open?id=0BwZZjRHl9NIJMGI1MTI3ZTEtYTk4YS00NzAwLWE3YjktMWRhZmRkODIzNTA1
go into recovery and follow my directions :)
Ok so I've copied the CID from the simple gold card program, what the hell do I do with it when I go to the website? I'm clicking the link but dont see anything there about putting this number in. When i click gold card generator, it just says they're on holiday.
mhamzahr
