[WIP][KERNEL][ROM] Wildfire S Virgin Mobile USA
Ok so I've copied the CID from the simple gold card program, what the hell do I do with it when I go to the website? I'm clicking the link but dont see anything there about putting this number in. When i click gold card generator, it just says they're on holiday.
that means there was a problem they cant fix till their back. Im sorry but your probably going to have to wait, there the only place
Lol what are the odds they just happen to go down now. Thats cool, it says they'll be back on Dec 10th so hopefully its up by then. Did you go to the website and look? Is there just something that I'm missing? I tend to go full from time to time.
I went and looked, all their pages but the home page are down. Check back every now and then, but i think we may have to wait. On the bright side, i have a rom built now
Reactions: Avengeme
Thanks so much. All seemed to work like a charm! Excellent instructions. One question: How can I confirm that the new 60681.prl that I downloaded was written to the phone successfully? There was no indication of a problem, but I am not sure how to confirm.
Again, THANK YOU!
Thanks simonsimons that wifi tether for root works much better than barnacle. It supports wpa2-psk instead of wep (a major plus) which i can use while on my touchpad now, and my pc picks it right up and my touchpad had no problems with it in WebOS meaning no more root commands to make it work, also works good in Xron's and cm's android port on it.
Also great work on the rom i might end up checking this out at some point :D
Its a great hold over. Keep it on the down low, but im talking to a kernel dev right now, working out the kernel. After we get this kernel we are good to go :D for CM7 that is
So I got the goldcard working and got the phone s-off. However, the one click root doesnt seem to be working for me. It keep saying stuff like adb out of date and killing daemon, nothing to indicate that it has actually worked. Tried running titanium backup and it would seem that I'm still not rooted.
whoot!
Awesome yo finally got the ROM going, could you put up a change log or how you improved over the stock.
If there's anymore than what's on xda.
Also I used the root tutorial on XDA with the s off method from here and it worked like a charm. Just check the dev section over on XDA.
I'd be happy to add a change log when I'm home. Also to root please consider flashing my Rom. It has built in root.
You have to go to task manager on your computer, than go to services and right click on htcUPCTloader and stop it from running, then it should work perfectly.
Well this is exciting :D Downloading CM kernel source, and then to build the kernel and test. Winter Weather Advisory here maybe no school tomorrow, meaning non stop deving:cool:
I hadn't heard of "EVDO" til now. According to one site, "EVDO (Evolution Data Only/Evolution Data Optimized) is a 3G mobile broadband technology used by Verizon, Sprint, and Alltel that provides typical download speeds of 600-1400kbps (with bursts up to 3100kbps)." Just thought I would leave that info here in case anyone else found it helpful or interesting. CHEERS!
oh snap son! CM is gonna make this little phone pretty beasty. i'm sure you have some testers, but if you need another i'm in. we've had some snow down here in west texas too, a christmas miracle:D
Nazeer zaheen
