Wireless charger won't charge phone to 100% overnight
We have a land line and my wife uses hers as an alarm clock. If you have a land line, missed calls would be less of an issue.
What's this "land line" you speak of? Is it at all related to this thing called "fax"? ;)
Yeah, I don't have a landline. And both my wife and I have different schedules so we both use our own as alarms.
I bought the RAV Power wireless charger. It's always at 100% when I wake up!
I'm on ATT and my Samsung Wireless Charger pad always stays at 100% after fully charged. Might be carrier issue
Sent from my ATT Galaxy S6 using Tapatalk
I use the round charging pad that was givin to me by best buy. It's the samsung one. Yes I wake up with my phone at about 93 to 97 % this is due to the charger having a feature that stops your phone being over charged. Witch will help ur battery last longer in the long run. You can see this on best buys website when I look at the description of the item. Nothing to do with the carrier or anything it's how it was designed. It just dosnt reconnect to the phone unless u pick up and put it back down.
Leave phone powered on and put the phone on the wireless charger before you go to bed (leave radios on). Let it charge overnight. In the AM (assuming you sleep 4+ hours) the wireless charger LED will be off and the phone will likely be less than 100%.
Please report back.
BTW, its likely not a phone software bug because the phone stays 100% charged when using the Tylt wireless charger. Sure, its possible the OEM Samsung charger has some other method to communicate with the S6 and maybe the phone OS is not communicating properly. I guess time will tell if we see a future software update magically fix the issue.
For me, I prefer the Tylt since I can use the phone while its charging.
I don't power off my phone at all when I go to sleep. When I wake up, the phone is all charged up with the charger light being green as well. It just stays charging like any normal wired charger...
Your charging pad remains at100% overnight? What your GS6?
I have an ATT S6 32GB. My phone is 100% fully charged when I wake up. The charging pad is lit up in green and my phone's led light is lit in green as well...
Just messing with you.
If you have a device that others have the same model and your device doesn't behave properly even after trying everything, take it back and exchange it. Or try another model until you find one that works best for you.
I've confirmed same problem with 3 phones and 2 Samsung chargers. Its either a software issue, or el bos had a special S6 made for him. ;)
And you have the "new" round Samsung wireless charger?
You may be the only one.... maybe it is a software bug.... How they got the evil deathstar version right is beyond me.
Haha! Yes, the round one...
mrtalha
