I picked up a Charge today from Costco. Two questions:
1. My old phone is an LG and the charging cable for the LG plugs in perfectly into the Charge. Is it safe to use the LG cable or will it/could it damage the phone?
2. The Charge I got today had about a 65% charge. Is this normal? In past experiences with new cells, they come completely discharged and this way you can give it a full charge on the first go around...allowing for better battery life. With all the battery issues being talked about, I don't want to be stuck with anything less than the best possible battery.
Thanks
Thanks
