How To Guide Too Install Android 4.0.4 update.zip
Eazy-go
20
Thanks I'll try that now. Will I loose all my apps and contacts and things?
There are some great backup options for rooted phones, so you can wipe clean, and restore your apps, and stuff..
I noticed a huge performance increase when I did a fresh upgrade.
scares me to think that some people are flashing without backing up...
ugean
15
I would back it up most of my stuff is sync`d to Google anyway. Just not worth the effort of doing it and restoring. If I have to in the end I will. I would rather a custom ROM anyway if anyone knows of one.
cslpainter
14
Re: Manually install ICS direction
ok so i have the update.zip on my sd card but then i go into recovery i cant see it
ok now im getting cant open error
tommyjoesanders
515
yea lg viper is rooted, and no i only deleted bloatware, sprint tv, sprint nascar, and nba, shopper...etc...
You will have too use unbricked method and reflash the phone and after you flash the phone do a factory reset from the phone. and then you can apply the update.zip using the guide
ugean
15
Someone please help. I had a rooted viper so I backed everything up did the unbrick method now twice. It says it fails at 98% but the posts say thats ok as long as it rebooted which it did. Phone appears completely stock. I go to do this and when I select the update.zip I still get "E:signature verification failed Installation aborted" How can I get this thing up to ICS? Thank you!
tommyjoesanders
515
do a factory reset from your settings
ugean
15
should I take the sd card with my backups on it out first? I don't want to lose my backups? Thank you!
justinedwards
