MrSmith317
Mr Fix-It
Can you still use Wi-Fi for Data while in GSM mode?
Yes, as long as the hardware works.. Why wouldn't it?
that's exactly what I did. I'll download it again, maybe it some how was corrupted. I just wish it take so long. Is anyone else hosting a mirror that is faster?
actually I just figured out the message is different tonight than it was last night. last night it read No Image only, repeatedly. Again, tonight it reads No image, and then No image, or wrong image.
I tried again and I got the same issue. The error it says once it reads the file is "No Image" and then "No Image, Or Wrong Image". I don't think I'm doing anything wrong. Could it be possible that my use of WinRAR to handle compressed files on my PC is causing the issue? Maybe it the phone does not know what to do with the file since it is a WinRAR formatted Zip file instead of a standard Zip file. I don't know enough to know if there is a difference, I just know my computer assigns a WinRAR Icon to any compressed file.
One thing to consider as well is the removable SD card is pretty much full. I'm not sure if that is making a difference or not, but i have a ton of music on it.
Question: Will flashing this leak erase everything on the internal SD memory or just the apps? Should I back up the internal memory first?
Now only if someone would answer your question...I can answer those lol.
No, root is not required, you must be stock to flash this.
If the OTA version number is higher (which it most likely will be) then yes you will receive it or be able to flash it the same way.
